Question about Daewoo DTQ-20U9SC TV
Service mode ihave changed eprom ic 24c32 i want to know how to enter in service main ic is vct3832 a c4
2 Suggested Answers
gopakumarg43
  • 74468 Answers
SOURCE: service menu mode
You should first check the output voltages comes out from its main power regulator section; and to rectify the cause of this shut down first. Then only, there is any need to enter its service mode. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given in detail.
Posted on Oct 30, 2013
How to reset eprom pensonic tv
What is the number of EEPROM used? The number of main system control memory IC? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Televison & Video
When I change picture settings from my remote why does it revert back to old settings
Main system control memory IC fault. Contact any service technician to replace it. Before replacing this IC; do a reset to this set and check.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 10, 2014 | LG Televison & Video
T SERIES T V
It will depend on the which the memory IC have been programmed. Contact the authorized service center. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 24, 2014 | Samsung Televison & Video
I want service mode vct3832
Press & Hold the Volume[-ve] button at the front panel of the TV, and plug it to AC mains. In most models of Daewoo sets, this must make the set in service mode state. The procedure may differ to model to model. To get some details, http://electronicshelponline.blogspot.com/Pull up older posts. Service mode entry procedure to some popular brand remote controls are given.
Dec 10, 2013 | Daewoo DTQ-20U9SC TV
Next crttv TDA9370ps/n3/3/0960 Standby mode I replace Eprom ic
Try by replacing its main system memory IC. It is a very small IC, have 8 solder terminals, and can be located very near to TDA9370. Be sure to replace it with the same number printed on it, otherwise wont go. It is a very cheap one to buy. If it do not help you, replace the TDA9370. Failure rate to this jungle IC is rare. Check all the related components, and make sure that all of it are OK, beofre replacing TDA9370. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
My tv is changing channels it self
The memory IC to your TV is faulty. Check and replace it. This is an eight solder terminal IC, can be located very near to main system control IC. Even though physical size to this IC is so small, function to it in circuit, when the TV works is great. You must have thofough knowledge in electronics to do this work, because, you might have to enter its service mode option to do some adjustments. This work is very skilled one, as service mode option window, and normal user window are entirely different to each other. Adjusting wrong data value to service mode options might make the TV irreparable, and irresponsive.
Jul 04, 2012 | Televison & Video
42hp66 toshiba will not change channels sits on channel 27. I do not have cable but the signal feeds other tv and this one was working this morning
I would say this has a software issue with the Eprom ic, I would try to get in the service mode and reset it to factory settings ( Google your model for service mode )
Failing this it will probably need a replacement av main board.
Mar 05, 2010 | Televison & Video
Repair hints
I hope you have a scope? then I can fix your set over the net!
Jun 14, 2008 | Philips Televison & Video
Blue is out
on the remote press mute 1-8-3 to enter,press enter and hold to write to eprom.
Sep 01, 2007 | Samsung HCL4715W 47" Rear Projection...
Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
Aug 31, 2007 | Zenith C27A24T 27" TV
Daewoo DTQ-20U9SC TV Logo
22 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
