Question about Radio Communications
My Motorola mr350 2 way radios are brand new but just stopped communicating. I cannot hear or talk using any of them. Don't know how to fix it
  • Radio Commun... Master
  • 1,654 Answers
Try reprogramming your radios back to a very basic mode with all the special features turned off (or set to zero), including the interference eliminator code, Qt filter (if any), and call alerts, etc. Make certain your frequency matches on both radios. The radios should communicate easily in this configuration. If not, since they are new radios, contact Motorola using the number your user guide and talk to them about warranty replacement.
Best regards.
Posted on May 09, 2013
Benimur
  • 6966 Answers
SOURCE: communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola t5100 cant hear the other person talking into the radio
Check to see you have the radios set to the same frequency and interference eliminator code as one another. This would be the most likely cause.
Here is a link to the owners manual http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Posted on Sep 27, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola t6500
You need to set your interference eliminator code to zero, and your Qt filter to zero also. Here is a link to the owners manual: http://direct.motorola.com/ENS/T6500%20Series%20User%20Manual.pdf
What is happening is your T6500 is set to ignore radios which do not match the same code. The fact your Cobras can hear the T6500 indicates they are set with their interference eliminator turned off (aka no code).
A similar occurance will happen if the Qt filter is set to anything but zero. The Qt filter is unique to Motorola. These features are beneficial when you are in a high radio traffic area and you want to block out hearing other people. But in your situation, you are mixing radios, and the easiest way to make them match is to turn off the special features (aka set them to zero).
Posted on Oct 17, 2008
  • 3287 Answers
SOURCE: I can't get the radios
These are multi-channel FRS / GMRS radios. In order to receive transmitted signals from the other radio, they both must be set to the same Channel and the same Interference Eliminator Code. One without the other will keep audio from being heard on the receiving radio.
I suspect you need to refresh yourself with the radio's controls and settings. If you have lost the manual, you can get a copy free of charge from Motorola You'll need a free program called Adobe Reader to view it.
Once you have everything - look at the right hand side of page 1 for "Talking and Listening" followed by "Menu Options" to set the radios up correctly. Keep in mind that if VOX is selected, and there is sound near both radios, they both will transmit at the same time - since the radios receive OR transmit at any given time, no audio will be heard from either.
Please rate this reply if helpful & good luck!
Posted on Aug 18, 2010
Ironfist109
  • 3018 Answers
SOURCE: How do I change and
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Posted on Apr 17, 2011
Can you stop motorola radio from beeping each time talk button is pushed
Nope...That beep lets you know that you can commence talking. If you start talking before you hear the beep, whoever you're talking to will not hear everything you say.
Sep 12, 2016 | Motorola Radio Communications
How do I get my motorola CP200 radio to stop making an annoying beep every time I transmit
Lincoln-
Motorola Solutions can help you with your radio. You can find their support available at Get Support .
Mark
Motorola Mobility Support
Jan 31, 2015 | Motorola CP200 Two Way Radio
I can talk but cant hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
I have a set of motorola fv700 talkabout radios. they wont transmit to each other. i checked the inter. elim. code. they are the same. and i have even turned them off. these are new radios. i know they...
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Aug 27, 2017 | Motorola Talkabout T5420 (14 Channels)...
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Don't talk to each other
What channel do you have to listen to the weather
Mar 10, 2013 | Motorola T8500 Two Way Radio
Fv150 walkie talkies won't communicate
Check your programming to be certain both radios are programmed identical, including frequency, code, and Qt filter if any. Go back to a very basic programming with all special features turned off and see if you can communicate. If not, then one of your radios may have a problem. The only way to discern which one is to put a 3rd radio in the mix and by process of elimination determine the culprit.
Here is a link to the user guide for the FV150: giantintl dot com/ContentManage-new/manuals/Moto/FV150%2012-19-07.pdf
You'll have to take out the word dot and insert a "."
Best regards.
Nov 22, 2012 | Motorola FV150 Two Way Radio
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
Regards, Tony
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
Motorola t6500
Oct 17, 2008 | Motorola T6500 2 Pack Rechargeable 2-Way...
Hello
if it's a single tone try communicating threw it. some of them have identifiers in them. you hear a beep but other on the same chanel may hear a different tone. this has been added over the past few years due to people talking on top of eachother, it does this to let others know someone is going to talk.
Jun 05, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
156 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
