Question about Olympus P 400 Thermal Printer
Printer error, only prints one color
My ribbon broke while printing, i replaced the ribbon catridge and now the printer will only go through one "pass" before ejecting the print. It was only printing yellow, then it would say printer error and push out the paper. It now does yellow, then red, then ejects the paper. Any ideas?
  • ukiah1921 Jul 09, 2008
    Sometimes  my printer will only make 1 or 2 passes and then stalls in that position with paper extended at bottom and will not send print back for the final color pass.  It will do this at any time... sometimes when sending one copy or in the middle of a multiple copy job.  Print dialog box says processing job and scroll bar is spinning but not advancing.
    I have turned it off and on... unplugged and re-plugged usb.  Usually have to turn off printer... remove the paper that was being processed... throw it away and start over... wasting unused section of ribbon until it happens again.
  • 390 Answers
Did any of the ribbon come away, or tear when it broke, i have heard of small pieces lodging in the carriage or feeder. Check this very thoroughly as blockages can be very tiny. Check you correctly inserted the ribbon too, and it is the correct type of ribbon for your unit. (sounds silly but sometimes it ccan be that simple) try reinstalling printer, is the ribbon cartridge faulty? check it.
Posted on Aug 11, 2007
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software has the driver for printer,troubleshooting and maintenence the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Prints are green
it can be due to ,, color catridge contains only green,, since the other colors,, are been used for prior printings,, and the green ink is left in the catridge,, you can check.. make use settings to print in gray scale,, dont use color.. then it should be fine.. but the color cartridge to be replaced
Sep 27, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer will not print colors
Printer not print colors. possible reasons....
  1. your color catridge may be empty.
  2. Your color Catridge may be jam.
  3. your color catridge may not be properly installed.
Aug 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Olympus P 400 Thermal Printer Logo
400 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
