Question about Cooktops
How to change ignitor on a ge jgp979bef2bb cooktop
SOURCE: my ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Posted on Apr 03, 2009
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
jumptrout51
  • 3361 Answers
SOURCE: GE Cooktop drop-in model # jgp328bec2bb - how to
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Posted on Feb 11, 2010
  • 234 Answers
SOURCE: ignitor does not click
there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
Posted on Apr 28, 2010
heatman101
  • 43501 Answers
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
GE JGP979BEFBB has one ignitor not working. How
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 05, 2010 | GE Cooktops
Ignitor does not click
Apr 28, 2010 | GE Profile JGP636 Gas Cooktop
Ge model jgp326 ignitor is giving
you either have a bad licon switch on one of the burner valves or you got water or cleaner in one of the switches.. Unplug it and let it dry for a few days, if it does not work you need a new switch.
Nov 11, 2009 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
May 30, 2009 | GE Cooktops
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Oct 18, 2008 | GE 30 in. JGP336 Gas Cooktop
Not igniting
Probably broken switch. or perhaps broken ignitor circuit. If only one burner is broken is then it is switch. if they all don't work check the ignigitor circuit.
Dec 16, 2007 | GE 30 in. JGP326 Gas Cooktop
Cooktops Logo
107 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
