Question about Ricoh Aficio 2228C Copier
Question about my color copier
Everytime I make a copy from the Aficio 2228c there is a yellow strip on the back of the page. Please help
  • Ricoh Expert
  • 1,326 Answers
Replace the yellow drum unit..... Or have your service person come out and do a general cleaning on your copier.. Good Luck
Posted on May 07, 2013
SOURCE: ricoh aficio 450
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Posted on Oct 12, 2007
  • 990 Answers
SOURCE: ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
Posted on Feb 10, 2009
SOURCE: Copier Prints Blank Pages
it must be due to the following reasons:
ur developer must be weak
transfer roller must be in problem.
led unit change in position..
u need to seek the help of the service engineer..
RICOH service centres in India
http://www.ricoh.co.in/about/salesnetwork.html
Posted on Jun 17, 2009
  • 990 Answers
SOURCE: I am getting yellow streaks accross the top header
Hello sir ; Suggest you replace yellow developer unit , it should take care this problem.
Posted on Jul 24, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
What does trouble code "SC
Hello Ryan,
It means your device went thru a self check in an effort maintain optimum copy quality. Your device could not get Magenta (pink/red) to even get close to the target values for that color. The most likely cause (and we hope so) is the Magenta development unit is toast. Replace it. But of course there are a myriad of other fun causes. As a sidebar, you might want to consider replacing yellow and cyan at the same time as they tend to croak at pretty much the same time. You have a quite reliable device as a rule. It's worth the cost. Take care. Let fixya know I helped ya please. SPINAL
Jun 18, 2011 | Ricoh Aficio 2228C Copier
How to access sp5 on 2228c when changing developer unit
the only way I can help you is to give you a service manual.
The service manual is for 3800C but it`s the same machine.
You can download the manual by clicking HERE.
Jun 06, 2011 | Ricoh Aficio 2228C Copier
In aficio 2228c the error code sc471...??
The unit of the transfer belt is not installed properly
Sensor defective transfer belt
Problem of unity of the transfer belt
May 25, 2011 | Ricoh Aficio 2228C Copier
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
How do I replace a drum on a ricoh aficio 2228C
It very easy...:) if you have a drum in hand.
Open the front cover. Lift one big green handle. Untainted 2 big black screws and open the drum cover. There you will see four groups of drum+development unit. Pull out the needed drum and pull in the new one. Then close all covers and that's all
pifonski
Mar 01, 2011 | Ricoh Aficio 2228C Copier
Black band on upper third of copy's
replace the black photoconductor unit. the black band is coming from the black drum unit.
Dec 10, 2010 | Ricoh Aficio 2228C Copier
Color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Dec 12, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 2228C Copier Logo
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
