Question about Dryers
I have a Kenmore Super Capacity Balanced Drying System 417.88042700 which is throwing some kind of error code. i seen that another person had the same problem and an expert attached a how to read error codes sheet. I cant read the sheet -it's too small and when i try to enlarge it gets blurry. i just want to know what all the beeping is for? it seems to be drying fine but the whole right column of lights flashes and beeps 3 time then pauses then repeats.
  • 619 Answers
SOURCE: Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Posted on Jan 20, 2008
Master_Tech
  • 770 Answers
SOURCE: e-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Posted on Feb 25, 2008
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
I have the same problem. Started a few days ago. My model number is 67086. How can I fix this? I have 2 year old twins and I'm concerned about the safety of this machine.
Posted on Nov 25, 2008
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
Dryer heating but cloths not drying
Hi Is good you start from wright leg Is probably limit sensor (not expensive) and next program board (is expensive). No error codes?? Check also outlet at wall where is connected vent pipe. Good luck.
Oct 19, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Dryers Logo
190 people viewed this question
Top Dryers Experts
