Question about Fujitsu fi-6130 duplex scanner
ERROR CODE SA01023E Scanning is canceled for the following reason ""Can't create file"
Label created with Zebra Bar One V5 read in Zebra Designer
Hi Jonathan. Did you ever reach a solution? We are in same baot with over 60 Barone v5 formats to convert to SAP. Thanks in advance. Mike
Jul 04, 2012 | Zebra DESIGNER FOR MySAP BUSINESS SUITE V2
Tip
How can I create a Barcode for Free in Microsoft Excel?
<p>Placing barcode equipment or other things makes it easier to keep track of them. Instead of entering a long number, a quick scan with a bar code reader eliminates keystrokes. There are many different types of barcodes. The most famous is the Product Code or UPC Universal, in almost all items sold at retail in the United States. The UPC format only supports encryption of the songs. Other formats such as Code 39 (also known as Code 3 of 9) support letters and numbers. <br /> <p><br /> <p>1. Find a free TrueType font to the desired shape of the bar code. For example, the Code bar code format is 39 different TrueType font packages available free. Use an Internet search engine and type "Code 39 TrueType fonts" available in a free font found. Some specialized formats may not be available for free as a result of copyright or other restrictions. <br /> <p><br /> <p>2. On your Windows PC, select the Start menu and click Control Panel. Within the Control Panel, click Switch to Classic View "and appearance of the panel. Find the" Fonts "icon and double click to open it. On the File menu, select" Install New Font. "This opens a menu dialog asking you to change the font to install. Navigate to the folder that contains the downloaded TrueType font file. Select the font and click OK when prompted to install it. The source of new bar code will be available in Excel. <br /> <p><br /> <p>3. Start Excel and enter "98765" in cell A1. This value is converted to a bar. <br /> <p><br /> <p>4. In cell B1, type the following formula: "= CONCATENATE ("*", "*")" A1 and press enter. The result should be "* 98765 *". Code 39 format requires an asterisk at the beginning and end of the text to be encrypted. Bar code format other will have different rules. <br /> <p><br /> <p>5. Change the font in cell A1, choosing a different font from the drop-down menu at the top of the screen in Excel. Under the menu "Home", scroll down to "three of the nine free" source and select it. The text in the cell will now appear as a barcode. Increase font with a minimum of 28 points, so a scanner can pick up the scanning needs. <br />
on Jun 26, 2011 | Computers & Internet
Meaning of error flag code 4,252,0
Cannot write or read file. - Code : 2,252,0
and because of it stops the scanning.
The following fixed the problem on all computers:
Activate the utility "MP navigator EX"
On the left-top click on Scan/Import
Click on "specify" (i.e. the settting for scan import) and change them to 75dpi and uncheck everything (I only needed to uncheck the "unsharp mask").
Test it now and it will work.
After that wills start working even restoring the settings.
Good luck.
Jan 15, 2012 | Canon Office Equipment & Supplies
Dear specialists, I've faced with error with BO Report: The excel file is updating every 15 minutes, but since yesterday BO creates corrupted excel file. Status of appropriate schedule:...
Excel unable to read file is able to resolve Excel repair worksheets, fonts, formulas, cells, columns, rows and etc. Software gives back excel data crashed by any reasons: viruses, incorrect actions anti-virus software, hard drive failures. Tool has the compatibility with Windows 98 and higher. Its interface doesn't require special skills and is simple for novices.
Jun 03, 2011 | Business Objects BusinessObjects...
My system is verry slowe working
It could be many reasons:
Your laptop/desktop doesn't have much memory or diskpace available
Your laptop/desktop may have spyware, malware, or viruses
Your laptop/desktop may have antivirus software scanning in progress
Your Internet connection is slow
Your laptop/desktop may have device driver issue.
May 13, 2011 | Computers & Internet
I press on the icon of Norton and then appears me Aiks red and written : " An error has occured with norton internet security Error:8504,104 " how to solve this problem?
There are many reasons for the issue.
Please check if the computer's date and time is running correctly, if not please adjust it and run a live update.
If that does not work, please download Norton intelligent updater from www.norton.com/iu and click on download definitions. Please select the first file if your computer is a 32 bit operating system or select the 4th file. Save it to your desktop. Once the download is complete, double click the downloaded file. It will update your Virus definitions.
If that also doesn't work, you need to reinstall the Norton program on your computer.
To reinstall, follow these steps:
>> download the latest version of the Norton program from the link www.norton.com/nis11
>> save the file to your desktop
>> Once the download is complete, double click the downloaded icon
>> it will remove the existing version while re-installing
>> Once the removal of the older version is complete, you will need to restart the computer
>> after the restart, please click on the downloaded file once more if it does not come up automatically
>> activate the program with the product key
>> your issue will be fixed
Regards,
Muhaim
Feb 26, 2011 | Symantec Norton Internet Security 2011 1...
Code 39
hi,
error code 39 stand for (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.)
Reason
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolution
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Sep 26, 2009 | Computers & Internet
Scanning error / not enough disc space to create file
Hi again, I Think the reason you cant use Microsoft Scanner and cam's but can use Office Doc scanning, is a setting that is set incorrectly in the other program so it is making bad/too big files, probally something like file type, resolution, colour. Or it could be using wrong scanning device.
Cheers
Feb 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Fujitsu fi-6130 duplex scanner Logo
347 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
