Question about Frisby Computers & Internet
Frisby FHD-U352S SATA dual docking station USB 3.0
Owners Manual is in Turkish and I need English. If you have a digital copy of the Turkish version then it will work as I can translate it. Any help is appreciated! Thanks for your time, Mickey
  • Mickey Martin Jun 12, 2013
    I am actually searching for my owners manual and driver disk for my FHD-U352S ATM. I'll let you know once I find and scans/attach it to your question.
    It's a great dock!
    Mickey
SOURCE: i ned the English version manual for Panasonic HDC-SD7 HDV Digital
http://panasonic.jp/support/video/manual/manual.html
Posted on Feb 04, 2008
ginko
  • 19396 Answers
SOURCE: HiPhone I32 DUAL SIM P168-9 English Manual
The manual should be available for download, I will post the link in one minute.
Posted on Sep 30, 2008
SOURCE: Pioneer DEH-P3000IB operations manual
How to set the clock on the DEHP3000IB?
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF] (power/source button)
Pres & Hold [Muti-Control] (big button that controls volume) until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segment.
Posted on Dec 10, 2008
  • 357 Answers
SOURCE: Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Posted on Nov 20, 2009
SOURCE: owners manual
I have an english version of the companion CD for Genio e550G. PM me at vu2dns@hotmail.com if anyone needs it. Put Genio in the subject.
Posted on Dec 17, 2009
How can Western Digital hard disk drives be recognized by third party USB external docking stations?
The format on a disk, will not be relevant of recognition via an USB connector. To connect a drive via USB, the computer must have the correct driver for the hardware you are connecting. Be sure you connect the HD coerce to the external harness and make sure it is supplied with the correct voltages.
When you connect a working system on the USB connector and the drive does not have a format, the computer will see that and ask you if it should format the drive.
Mar 04, 2015 | Western Digital Computers & Internet
How do i connect a hard drive in the usb port
You need a hard drive docking station. It has a USB cable linked to a hard drive plug-in connection. The plug-in section should have an option with the same pin arrangement as the hard-drive. The hard drives generally have male pins so the docking station should have female pins.The docking stations generally have more that one pin arrangements for different types of hard drives ie. SATA etc.
Check with your local electronics shop, if you have one, else explore Ebay and/or Google.
Feb 13, 2015 | Hard Computers & Internet
Which USB cradle works for a WDAC24300?
Okeba 2.5" 3.5" SATA IDE Hard Disk Drive HDD Dock Station Clone With USB HUB card reader - CA130 From - Rakuten.com,
or: Sisun 2.5"/3.5" IDE SATA HDD Docking Station +Card Reader Hub - From Amazon.com
Feb 12, 2015 | Western Digital AC24300-00LK 4.3gb 5400rpm...
Kingwin ez-dock 2 dosen't support 3 tb hhd
I bought a dual drive SATA enclosure and found out after purchase that only 1 drive could be active at any one time. I had to manually switch dives on and off. The reason was that the enclosure did not have a SATA drive multiplexer in it and neither did my laptop's Esata connector. A similar issue with USB.
Mar 06, 2014 | Kingwin EZD-2536U3 - Ez-dock2 2.5in Or...
What power plug do i use with unitek data hdd docking station
The Y-2041 comes with a 12V 4A power supply which is not quite as large as the typical laptop supply. It is manufactured by Ktec and the model is KSAH1200400T1M2.
Jan 19, 2014 | BestOfferBuy Unitek Y-2041 USB 2.0/eSATA...
Docking station with known good SATA drive is not visible in My Computer
check the drive is visible to windows...
control panel>administrative tools>computer management>storage>disk management
it will list all drives (even ones you can't see in explorer)
assign it a drive letter and make it active from there.
May 10, 2012 | BYTECC T200U3 25_35 Black USB 30 Single...
Hi, I connected my monitor and my ethernet cable to the dockingstation SD400V, But there is no connection at all. No internet access and no image on my monitor. Can you help me?
Hi
I had trouble with this Docking Station.
Use USB 3.0 and try this:
1) follow this instructions: http://support.euro.dell.com/support...l=pl&s=gen&cs=
2) restart, unplug docking station
3) install this software: http://www.displaylink.com/support/downloads.php, version 6.1
4) restart
5) plug docking station
After all, it should working.
In any questions, write: pawel_surowiec (at) o2 (dot) pl
Mar 30, 2011 | Kensington SD400V USB Docking Station with...
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Owners manual
May 30, 2008 | Toshiba Genio e550
Computers & Internet Logo
247 people viewed this question
Top Frisby Computers & Internet Experts
David Payne
David Payne
Are you a Frisby Computer and Internet Expert? Answer questions, earn points and help others
