Question about Fujitsu fi-6130 duplex scanner
SA01032E Scanning is canceled for the following reason 'can't create file
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
When scanning to a PDF file for multiple pages from the glass, the file won't process and create. I have tried a RIP and clean re-installation of the software but it doesn't make a difference.
Make sure that the Lexmark OCR scan software is installed on your computer. The software aids in creating PDF files and combining multiple-page documents into one file.The software is only available on the installation disc that came with your printer. If you don't have the install disc, please contact Lexmark Technical Support Center for assistance.
Oct 18, 2011 | Lexmark X7170 All-In-One InkJet Printer
My system is verry slowe working
It could be many reasons:
Your laptop/desktop doesn't have much memory or diskpace available
Your laptop/desktop may have spyware, malware, or viruses
Your laptop/desktop may have antivirus software scanning in progress
Your Internet connection is slow
Your laptop/desktop may have device driver issue.
May 13, 2011 | Computers & Internet
Trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
I do not believe Nikon made drivers specifically for Vista, but you can use the solution here to make your own driver "inf" file and install some that will work anyway. Please read this and carefully follow the directions. If you are using 32 bit, use the 32 bit drivers. If 64 bit, then 64 bit drivers, when creating the new inf.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Nov 16, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
I can't figure out how to scan multiple pages to one file
Hi There !!
Thank you for choosing fixya.com
It is possible to scan different batches scanned from the ADF into one PDF file. When loading more pages in the ADF after the first realm is finished, it asks if you want to continue scanning to the same file. After that, it will continue scanning to the same file. However, this feature can be selected in the Adobe Acrobat application itself. From HP software, if we load the paper after one realm of paper in the ADF is finished, it will scan the second realm to a different file. If you want to continue scanning to the same file, you need to have either Acrobat Exchange or Adobe Acrobat installed on the computer. Adobe Reader will not provide this feature. After installing either Adobe Acrobat or Acrobat Exchange, perform the following steps to scan pages to a single file:
  1. Make sure your scanner is turned on.
  2. Start Acrobat Exchange or Adobe Acrobat.
  3. Put the document into the scanner (usually face down on the scan bed).
  4. In Adobe Acrobat, click File , then Import , and Scan .
  5. Select the device and whether you are scanning a single- or double-sided document.
  6. The scanning software opens and the scanner completes a preview scan.
  7. When the preview scan comes up, make any adjustments you would like, including selecting the area you want to appear in the final scan.
  8. Click Scan . This will get the final scan into the computer.
  9. Your scanning software should take you back to Adobe Acrobat.
  10. In Adobe Acrobat, you should see a small window asking you if you want to scan another page. If the document you are scanning has more than one page, click the Next Page button. If this is the only page, click Done .
    NOTE: Scanning multiple pages causes each page to append to the previously scanned page. If you have multiple pages, but want them to be in different files, click Done after each page to create separate files.
  11. When you have scanned the last page, click Done on the window described in step 10.
  12. Your scanned pages will open in Adobe Acrobat. Scroll through to make sure that everything is there.
  13. Click File , and then Save As to name your file and save it.
Still unable to figure out, How to do this? Here are some tutorial on HP website that might help.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1161389&prodTypeId=18972&supportTaskId=23095
Hope this would help.
Regard's
Anurag Shukla
Sep 04, 2009 | HP LaserJet 3055 All-In-One Printer
4355 all-in-one not scanning
Right click on the Wdws Icon in the bottom left hand corner of your computer (same as the start button for other features with a left click)
Click on Explore
Find and click on Program files
Find and click on HP folder or Hewlett Packard Folder
Find and Click on Digital Imaging Folder
Double Click on BIN folder
Find the following file: hpqscnvw
Double click on that file (hpqscnvw)
Your HP scanning feature should open
I am thinking I may just create a shortcut of this and launch from that instead of HP solutions center if HP cannot fix this issue.
Let me know if this works for you.
if yes rate me
or
email me
blog: www.freecomputercourse.blogspot.com
Jun 25, 2009 | HP Officejet 4355 All-In-One InkJet...
HP 1410v all-in-one scanner won't work
Please follow the steps given below to scan from other applications.
Windows XP:
Scanning from Microsoft Paint:
1. Click Start, click All Programs, click Accessories,
and then click Paint.
2. Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
3. If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software
will appear. Preview the image by selecting Preview,
or click "Scan" to scan the image directly into Paint.
4. The image will open in paint for editing and/or saving.
Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
1. Click Start.
2. Click Control panel.
3. Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If it is possible to scan from any of the above methods, try to scan from HP schortcut File and get back to me with the results.
Scan Shortcut:
1. Search for the file hpqscnvw.exe
2. File should be available in the following location
C:/Program files/HP/Digital Imaging/Bin folder
3. Create a shortcut on the desktop and double click the same
to activate the scanner and try scanning.
Windows Vista:
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs
3. Click Windows Photo Gallery
4. Click File and then click Import From Scanner or Camera
5. Click Import
6. Click Scan
Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate,
Windows Vista Business, and Windows Vista Enterprise.
1. Click the Start () icon.
2. Click All Programs.
3. Click Windows Fax and Scanning.
4. Click New Scan.
5. Click File and then click Scan.
Scanning with Paint
1. Click Windows.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Scanning from Shortcut File
* Click on the Windows logo to access the start menu.
* Click on Computer.
* Double click on C:\drive icon.
* Double click on Program Files folder.
* Double click on Hewlett Packard or HP folder.
* Double click on Digital Imaging folder.
* Double click on the bin folder.
* Locate the hpqscnvw.exe file and double click on it.
Vishwanath V U
May 19, 2009 | HP PSC 1410v All-in-One Printer
Scanning error / not enough disc space to create file
Hi again, I Think the reason you cant use Microsoft Scanner and cam's but can use Office Doc scanning, is a setting that is set incorrectly in the other program so it is making bad/too big files, probally something like file type, resolution, colour. Or it could be using wrong scanning device.
Cheers
Feb 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Scanner won't work but the printer does
Ok here is the answer you have all been waiting for - look on the CD that came with any HP printer for the mac and you will see that it is for 10.3.9 and 10.4. I bet you dollars to donuts you have the new 10.5 leopard software and you got the new printer for free from the apple store.
All is not lost - go to the hp website at www.hp.com and on the left side you will see a grey menu that says software and driver downloads click on it and type your product. The version right now is 9.7.1 once you get all the way through. DO NOT INSTALL THE HP INSTALLER FILE - it is the same as the CD.
Well on the off chance your using windows the same applies - delete the old software on your computer and follow the steps above. The version number you will need depends on what OS but just make sure it is the most recent and you should be fine.
Jan 22, 2008 | HP PhotoSmart C4280 Laser Printer
Fujitsu fi-6130 duplex scanner Logo
184 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
