Question about John Deere Garden
How to adjust the drive tension on a john deere l130 riding mower?
I have a john deere l130 riding type mower, with a 48 in mowing deck, and a 23 hp kohler engine. After mowing for 20 min. the mower wont go up a hill or go in reverse. I have changed the traction drive belt and the tension spring and I am still having the same problem.
3 Suggested Answers
  • 7 Answers
SOURCE: I need a belt routing diagram for a John Deere
If you go to this page http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO , scroll down the left side to the heading for your deck.
Posted on Aug 22, 2010
SOURCE: How to change the Belt on a John Deere L130 with
why cant i get simple routeing diagram for the belt on john deere l130????
Posted on May 03, 2013
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
How to fit a 48 inch deck to john deere x110
Who told you that would fit? Take it back and get your money back.
Dec 13, 2013 | John Deere 22HP VTwin 48" Riding Mower
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
How to change the Belt on a John Deere L130 with 48" mower deck? Is there a Belt diagragm that show proper routing?
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
Sep 18, 2010 | John Deere Garden
I need a belt routing diagram for a John Deere L130 riding mower. Deck belt, 48" cut 23 h.p.
Aug 22, 2010 | John Deere Garden
Garden Logo
362 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
