Question about Garden
Ryobi ex26 weedeater fuel line
Gas line
SOURCE: gas/oil mixture for ryobi weedeater
It is 2.6 fl oz of oil per 1 gal of gasoline.
Posted on Apr 29, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
  • 59 Answers
SOURCE: New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
Posted on Jun 23, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
SOURCE: where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Posted on May 10, 2010
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Aug 01, 2009 | Ryobi Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
Ryobi EX26 dies when hot, won't start, then when cool starts
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
