Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frs26hf5a adc I have my thermostat on my refrigerator turned down below 1 and everything is still freezing up do I need a new thermostat
  • Official Brand Answer
  • 4,342 Answers
Good Morning mclellan286 - There could be various reasons why your refrigerator is freezing. There could be a faulty defrost thermostat or the vent from the freezer has been blocked and is forcing air into the refrigeration section.
If I may suggest checking to make sure that items in the freezer are clear from the vents or walls in the freezer. If this is not an issue, it may be more of a technical issue and an authorized service provider would be able to determine the root cause to reduce the risk of unnecessary parts.
If you do not know a professional technician, manufacturer websites often have service provider locators' onsite to assist you in that regrd. If you have any additional questions, please feel free to reconnect!
Posted on May 18, 2013
4 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: refrigerator side is freezing.
The damper control which is the control for the refrigerator has gone bad not letting the damper door close to control the airflow into the fresh food section. the part number is 5303918283 at a price of about 245.00. To me this is rediculous but that is the manf suggested retail. It should be a crime to charge so much for this particular part. Soory on the cost but it is the problem.
Posted on Jun 02, 2010
  • 531 Answers
SOURCE: My Frigidaire two door Refrigerator freezes food
door not closing (ajar) or cold control is bad or defrost problem
Posted on Apr 03, 2009
  • 132 Answers
SOURCE: I have a 20 year old sub-zero refrigerator. For
It sounds like the freezer side is losing its capacity......All cooling done on the refrigerator side is done by air flow of the fan in the freezer compartment by the evaporator coils(aluminum fins looks like a radiator)
You might want to pull the back panel of the freezer section and look at it.
Normally it is fully frosted when running(whitish snow covering on evaporator) If it is only partially frosted it has a freon leak or compressor problem. If it is engulfed in frost and there is no air flow possible through it your defrost system has failed.My guess is it is partially frosted and you have a freon leak.
Also check the fan by the compressor is running on the outside and the condensor coils on the outside on the bottom are clean.( fan runs when compressor runs)
A
Posted on Jan 14, 2010
Testimonial: "Quick intelligent response! Thank you!"
Illogical ADC assembly (updated info)
Check your coils to see if they are dirty. If they are underneath the refrigerator you can vacuum them as best you can, or if you have access to an air compressor, you could try blowing them clean. Too much dirt on the coils can make you unit work harder and cause warmer temps. What is your temperature in the freezer section. You only need 32 degrees to freeze things, but it should be down below 10 degrees for everything else to work right. Hope this helps!
Aug 05, 2015 | Refrigerators
My Frigidaire brand refrigerator blower motor does not run. where is it located on my model#FRS26HF5A?
There are 2, one in the freezer behind a sheet metal cover mounted over the evaporator and the other next to the condenser. It is in the bottom back of the unit and behind a carton cover.
Mar 03, 2015 | Frigidaire Refrigerators
My Frigidaire brand refrigerator blower motor does not come on. Where is it located in this refrigerator?
Your evaporator fan is located in the back section of the freezer. In this particular model the fan is energized by the ADC(auto defrost Control) which is in the control panel in the fresh food section. Behind the thermostats. The red wire with a white tracer is the power feed to the fan from this control. The condenser fan is beside the compressor in the back of the unit.
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
Fridg. not cooling. digital display not working, frezzer thawing.
First Test Method:
Second Test Method:
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
Have a Fridgidaire # FRS26HF5A that has stopped cooling. All the lights and fans inside are working. The compressor and cooling fan for the coil are not working. I have checked the voltage at the...
Hi there
There are 2 possibilities
1. Bad thermostat (cold control) there should be power to both terminals on this, if there is only power to one then the thermostat is the problem.
2. ADC failure, there should be power at E8, that is power input to the board there should also be power at E2 (return from the thermostat), this input tells the ADC to switch the compressor on. Check for power at E3 this is the red wire that feeds the compressor. If you have power here then there is a problem between here and the compressor, a wiring fault.
I think however that it will be either the thermostat or the ADC
Regards
Gordon
Apr 25, 2011 | Refrigerators
How do i get unit to go in deforst
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Refridgerator acting erratic
First Test Method:
May 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirpool frost free-fridge temp is not working
First Test Method:
Second Test Method:
� If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
� If the relay clicks two times, check for an open bimetal.
Jan 06, 2009 | Whirlpool Refrigerators
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
