E004 0203 The Following Error Code Appears on the lcd panel: E000004-0203. The copier also has a message to call a service Rep. We shut down the machine and turned it back on, the error disappeared, but I curious what the message was caused from?
  • 186 Answers
SOURCE: I receive an error E000013-0000
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Posted on Jul 03, 2007
sir fixalot
  • 146 Answers
SOURCE: I receiver error number E000067-0110
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Posted on Jan 02, 2008
  • 62 Answers
SOURCE: canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Posted on Feb 18, 2009
Copier_God
  • 57 Answers
SOURCE: Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Posted on Oct 16, 2009
  • 158 Answers
SOURCE: error code c-d369
this is a nvram error code most likely the nvram board will have to be replaced and konica minolta has made the procedure for obtaining this board very hard so i am sure the copier repair company you are using is aware of the cause but ti is going to take some time to get the part that is needed to fix the problem. the reason for the procedure and paper work to get this board is all the counts and settings for the machine is stored on this board and some lets just say dishonest copier repair companys could but a used 250 with a lot of copies on it and replace this board then sell it as a new machine.
Posted on Nov 28, 2009
Error code e000004 0401
1. Make the following selections in sequence to perform the error clear:
[Service mode > COPIER > Function > CLEAR > ERR].
2. Turn the control panel switch OFF > turn the main power switch OFF/ON.
3. If the error code still persists, check to see if the connector [1] of the fixing thermo switch is disconnected or the pin [2] of the receiving side connector is bent. If the connector is disconnected, re-fit it.
Jul 29, 2013 | Canon imageRUNNER iR C4080 Color Copier
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
I have problem with my canon copier image ready 5020. error E000004-0000 how do I fix it i'd tried to press 2&8 but its said "Download Mode"
Error E000004 is a fuser related code and is most parts just caused by a paper jam in the fuser area. Before you begin to try and clear the internal flag you must make sure there is no paper or no obstruction stuck in the fuser area. With the power off rotate the fuser model handel to see if any aper or obstruction exsists. Clear it carefully if there is. At any time NEVER USE a knife or sharp object to clear a jam. Common sense I know, but few practice it. Once you clear the paper jam you can see if clearing the flag is the magic you need. If the next stages fail contract a local Canon trained tech to troubleshoot the real source of the error. Clear the error flag do the following steps DO NOT touch any thing else DON'T adjust any numbers. Turn machine on. When main screen apprears press Additional Functions button (*) let go. Press 2 and 8 together let go. Press Additional Funtions button (*) again. Screen should say Service Mode Level 1. Press these screen buttons in the following order. Copier, Functions, Clear, ERR then press OK in lower right corner. Machine will apprear as if nothing has happened but it has. Shut machine off at side. Turn on. Flag is cleared. If code reappears get professional help. This is a fuser code therefore we don't want a fire or anything else happening. Doing this clear you have 30 seconds before macine shuts off. It takes timing. Good Luck.
Jun 28, 2011 | Canon imageRUNNER 5020 Copier
How can i cancil error 0004 ?
To clear the error code you must enter service mode level 1 first. Once in service mode you choose in the following order Copier>Function>Clear select ERR and push ok. At this point it would apprear nothing has happened but in fact the error flag has been cleared. Shut the machine off. Now turn on. If your error was minor and your cleared the cause of your error E000004 then the machine will operate as it did before the flag went up. If you get the error code again look for a Canon trained tech in your area to correct the issue. If you do not know how to get in to the service mode level 1 your best to search for entering service mode canon. As I don't want to promote persons without expertise entering the machine service and adjusting things without any backgound. Good Luck
Jun 25, 2011 | Canon imageRUNNER 5000 Copier
Code show on the copier screen:E000004-0010 it's my problem and we can not copy document, so how do we slove this problem Thanks
error is due to fixing unit.clear it in service mode additional function 28 additional function button. go to function then to clear then click err then ok restart the machine wola.
if this not clear the code then u have to call a rep to have look at the unit
Jun 06, 2011 | Canon imageRUNNER 5000 Copier
In canon 6570 when machine is switch ON error E000004-0106 and sometimes E000004-010 appears , what is the reason?
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Sep 28, 2010 | Canon IMAGERUNNER 6570 Copier
I have a canon 4080i error code e000004-0401 comes up and have to shut down when retart get the same message.
you have a fuser related error code, either thermisters or thermo fuse.
to reset error code you need to go in to a service mode and reset it.try this hit the additional fuction button then hit 2 and 8 keys together and additional function button again that will put you into service mode BE very careful in there though.
under function/clear/err code highlight err code then ok reset machine see what happens if error code comes back then you need to get a tech to have a look at ya fuser
Canon Tech
Apr 09, 2009 | Canon Office Equipment & Supplies
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
power down copier at op-panel.straightend end of paper clip into little hole by op-panel power button.hold in till little dot appears on screen in middle to the left.press #3.that should get you to trouble reset.Or sometimes opening and closing rightside door can reset.
Dec 01, 2007 | Konica Minolta DiALTA Di200 Copier
228 people viewed this question
k24674
jasbo
jasbo
