Question about Toshiba Office Equipment & Supplies
Copiers We have a technical fault with the model e-Studio 756. The problem is,paper is folded as shaped while duplex copying. This problem occurs only in duplex copying. Thank you very much in advance
  • Toshiba Expert
  • 1,326 Answers
Odds are you have a small piece of paper blocking the paper path of the duplex or you have a clutch that is slipping.
Posted on May 07, 2013
  • Chris Coughlin
    Chris Coughlin May 07, 2013
  • 8 Answers
SOURCE: toshiba e studio 161
already paper jam in feeding assembly so please check any paper jam.or lubricate all drive gears
Posted on Jul 25, 2008
SOURCE: Copier - Paper does not feed/paper jam light keeps going on.
Depending on the type of machine, it is probably just dirty rollers that pick up your paper (slipping). If you remove the tray, and look inside you should see some rollers (usually gray) that take the paper from the tray. Use a cloth dampened with some alcohol(if you have it) or simply water to clean these rollers (gently).. dry if you have used water, the top sheet or 2 of previously used paper, and try it.
Posted on Feb 16, 2009
20YrsCompExp
  • 227 Answers
SOURCE: e studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Posted on Apr 13, 2009
firecontrol7
  • 6161 Answers
SOURCE: duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Posted on Apr 03, 2010
  • 628 Answers
SOURCE: Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Posted on Apr 13, 2010
How do I make double sided copies
On the basic menu press the simplex button then press 2->
Aug 03, 2011 | Toshiba e-Studio 350 Copier
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Jul 09, 2010 | Canon Office Equipment & Supplies
Hey I have installed a duplex unit in my canon iR2018 it was copying normally before I install it and now it is having paper jam after installing the duplex unit
did you properly conect the all connectors?
See instalation manual.
Maybe the duplex unit didnt set very well.
Where paper jam occurs?
Try to clean all rollers on duplex, maybe the unit were very long time stored badly.
Pls. give more info!
Jun 14, 2010 | Canon iR 2016i Black and White Copier
I am having a 6551 canon copier and I am getting the problem in the duplex. When I am taking copy in overlay mode. the over lay mode first copy is coming and when the paper is in duplex. the second copy is...
sounds like the registration rollers and the duplex rollers need to be replaced. they have finnally gotten worn out to the point that single sided copies are fine but the paper slips during the duplexing and offsets the copies
May 17, 2010 | Canon NP 6551 Black and White Copier
Apr 05, 2010 | Toshiba e-Studio 205 Copier
Sheets are getting the corners folded as they pass through the fusing unit. This occurs both single and double sided. Tried replacing the transport belts and adjusting pressure? What next?
Check the stripper fingers to ensure they are sitting flat and flush against the pressure roller. These are thin fingers of metal about 3/8 in wide that ride against the pressure roller to strip the paper away from the pressure roller. These can sometimes bend up or have toner deposits on them that will cause this type of problem.
Apr 02, 2010 | Ricoh Aficio 1085 Laser Printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
49 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
