Question about Microwave Ovens
How do I operate the defrost function on Tesco microwave MTG06
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave TimeCook defaults to Defrost Auto
It sounds like your keypad (membrane switch) is failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. You can use it to test for a bad keypad.
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link her eon Fixya http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Have a tesco microwave Model
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: how do i reset my
UNPLUG AND REMOVE FUSE..PLUG IN AGAIN, UNPLUG RPLACE FUSE. MAY HELP.
Posted on Oct 16, 2010
  • 8909 Answers
SOURCE: I have a MTG06 combination
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps
Posted on Jan 09, 2011
SOURCE: how to use the Tesco mtg06 microwave grill?do not
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Posted on Jul 29, 2011
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
How to use the Tesco mtg06 microwave grill?do not have instruction manual
Jul 29, 2011 | Sanyo Microwave Ovens
I have a MTG06 combination microwave oven and grill that i purchased from tesco. i broke the glass turntable and need a replacement, where can i get one other than from tesco Thanks
I hope this helps
Jan 09, 2011 | Microwave Ovens
How do i reset my microwave it's stuck on autocook? Tesco MTG06
Oct 16, 2010 | Microwave Ovens
MTG06 Microwave Oven not heating up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Sanyo EM-D1100 1100 Watts Microwave Oven
Have a tesco microwave Model number - MTG06 bulb blown ho do i replace it
Jan 24, 2009 | Microwave Ovens
Mar 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
LMV1630 doesn't heat
check control panel circuit, and related circuit.
Oct 27, 2007 | Microwave Ovens
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
