Humax 600E error - Computers & Internet
My laptop IBM ThinkPad 600E 2645 by turning on shows the notice Error 129 in system board. The laptop cannot be put into service.
The ThinkPad error code 129 is a motherboard problem. This is a component failure on the motherboard and cannot be fixed easily.
The 600E is a very, very old laptop. I suggest you don't spend money on it, put your money towards a new or later model laptop.
Aug 18, 2010 | IBM (30L2872) for ThinkPad 600E 2645-55x...
I have ibm 600e 2645...error 161 and 163....Replaced my bois battery and still get the same error. I reset the clock and I still get back to the OFF and ON site which leaves me nowhere
after the error you need put the right date and hourly push ok later hold the button to off - turn on if the problem continued is a motherboard problem
Mar 18, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpap 600E 8611 error
http://www.repairspot.com/thinkpad_8611_error__disabling.htm
pls rate this solution if it works
thanks to choosing FixYa.
May 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Error 191
191 is a fan error. While it is usually associated with a dead CMOS, a bad fan could cause your problem.
600e system boards are quite cheap, and take around 30 minutes to replace.
Mar 28, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E problem
might wann redo it or repiar it with orginal xp cd ok boot into cd
Jan 25, 2008 | IBM ThinkPad 600E 2645 Notebook
Error codes for ibm thinkpad 600E
Your bios battery needs replacing
http://www.bioscentral.com/misc/ibmdiag.htm
Hope that fixes it for you? :)
Jan 06, 2008 | IBM ThinkPad 600E 2645 Notebook
08611 Error
I'm not sure about the 600E or that error number but the same F1 or ESC key sequence might apply(from your other post)! Good Luck! regards, Babb
Apr 28, 2007 | IBM ThinkPad 600E 2645 Notebook
My ibm s showing a certain error no. on startup
Without seeing the error, you may be best just typing the number into Google.
Feb 20, 2007 | IBM ThinkPad 600E 2645 Notebook
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
