Question about GPS
Simrad CA 42 won't power up
I have a Simrad CA 42 which has died. It was working fine but suddenly stopped. I have checked all the fuses in the power supply and a single fuse on the circuit board and all are fine. The power lead is ok and power is being applied to the crcuit board from the power terminals. I have checked the 3V memory battery and this appears ok at 2.7V. All the connecting ribbons are secure. I have also tried a factory reset to no avail. When power is applied and the power key pressed the keypad illuminates for a second before going blank and no keypad tone is evident. The screen stays blank and dark although, when the power is removed it appears to lighten but remains blank. Does anyone have any suggestions as to a possible cause please? Thanks.
MicrowaveSvc
  • 9047 Answers
SOURCE: sudden death of the range hood
Did you measure the continuity of the primary and secondaries of the transformer which drops the line voltage to supply the front panel? Any chance you could scan and post the "mini-manual" that comes inside the unit? I repair just about any kind of control board / system out there, in case you might be interested. My listing is here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 08, 2007
bigjohn007
  • 425 Answers
SOURCE: RAZR will not power up
hi
you have a software prob.. have you fon flashed...
im sure your prob is solved...
give me feedbacks...
Posted on Oct 16, 2007
SOURCE: powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Posted on Jan 10, 2008
hydetech
  • 113 Answers
SOURCE: Magellan 315
That unit does not have a touch screen so holding the screen while powering up wont do anything. I'm not sure which key it is on that model, but to do a reset you hold down one of the keys while powering up. Try holding down the enter key while you power up. If that doesn't work, try again with the other keys until you find it. If it doesn't reset, you may have a dead keypad.
Posted on Jan 26, 2008
SOURCE: My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Posted on Jul 28, 2008
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
TV all the sudden won't power on. Where is the fuse located?
Follow the power cord inside the set as it goes almost directly and non stop to the AC line fuse.
Dec 06, 2012 | Sharp 32U-S60 32" TV
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
I have a newer craftsman riding mower, its a 24 horse, 42 inch cut. When I was mowing today, the deck cut off then the mower died. Upon inspection, I discovered a blown fuse (20 amp), I replaced it and it...
By uping the fuse rating you are definitely putting your equipment at risk for damage. The 20 amp fuse is doing it's job. what you need to do is find the reason it's blowing. Stop running you newer machine with the 30 amp fuse and look for the high current source. Hopefully you know what the fuse is protecting and start looking there. A fuse blows due to a high current condition. If it's a motor it could be a mechanical binding of some sort. If it's wiring, it could be caused by a loose connection or exposed wire shorting itself to ground. Look for signs of obvious damage first but if you can't figure out what it is you should have it checked out by a profesional before you cause more, damage and expense.
Jul 10, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
May 27, 2012 | Simrad GPS
Stop on stop sign engine died
If the engine won't fire up, but your starter turns over, you may want to check your timing unless you have a check engine light on. If the CEL light is on, have the codes scanned.
If the engine won't turn over with the starter or it clicks, have your battery tested at autozone or advanced auto parts. Replace the battery if it is bad. Else, have your starter tested.
If the engine still won't turn over and the battery and starter are tested fine, you may have a blown fuse, bad ignition switch, or a failed relay.
If the engine fires up but randomly dies and starts back up, you either have a failed sensor, failing fuel pump, clogged fuel filter, bad plugs or wires, or a failing ECU.
Sep 06, 2011 | 1996 Nissan Quest
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
GPS Logo
252 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
