Question about Ovens
GE Profile JGS968SOH3SS will not heat
Cooktop and Broiler work. YouTube videos seem to indicate igniter problem. How do I access it? The bottom pan cannot slide out as it is blocked by the door
SolutionGuy
  • 331 Answers
SOURCE: Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Posted on Sep 15, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
fixyourboard
  • 310 Answers
SOURCE: GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Posted on Aug 31, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
The glow bar ignitor for the GE (jgrp17) oven is not working ( however I did not measure with VOM ) the broiler works....I am attempting to remove the ignitor to replace it I need to know if the ignitor...
There is a lot of troubleshooting and repair advice at the link I'm providing. In addition, they have parts available and hot-to videos. I'm sure you'll find your answers there.
GE Oven Not Heating
Jan 03, 2018 | GE JGRP17 Gas Single Oven
Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
Jim your ignitor has gone bad once again.
You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Jan 01, 2010 | GE Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
GE JGBP90MEB oven not lighting. Broiler working
Igniter needed to be replaced. GE fixed it the same day.
Sep 18, 2009 | GE Ovens
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
166 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
