Question about Spectre 2006 Ford Econoline - E250, 4.6L V8 - Air Filter
Code po351 i got codes po351 353 354 ive took them out made sure they were snug and the van keeps stalling as im slowing down to stop what could be the problem
  • Spectre Master
  • 16,002 Answers
Its not the plugs. It is either the ignition coils or the crank sensor
Posted on May 12, 2013
We took our camry for inspection,but we were told the diagnostic monitors are not ready?
Try another auto parts store. Most will read your error code for free, so they can sell you whatever you need.
Jan 28, 2015 | AM Auto Parts 1994 to 1995 Toyota Camry...
The hand held unit of my ergorapido works, however when in the stick the unit will not work, it seems to fire up then stops
check under neath to see if the bel is connected or it broke if its not sucking im not really sure how to answer that ive never had that happend it can be a wiring issue or switch it sounds like it can be the switch might need replacing the power or the pedal that unlocks it from the stick mode might be pinching somthing that stops it
Dec 05, 2014 | Electrolux EL1022A Ergorapido 2-in-1 Stick...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
My oreck magnesium keeps turning off. Blue. Light keeps blinking
THE PROBLEM SEAMS TO BE WITH THE THICKNESS OF THE CARPET AND THE PAD-ALL VACUUMS NEED TO BE ABLE TO BREATHE IF THE PAD AND THE CARPET ARE THICK THE VACUUM WILL PULL ITSELF TOWARD THE FLOOR SLOW DOWN THE BRUSHROLL ENOUGH TO TRIGGER THE AUTO SHUTDOWN ON THE MAGNESIUM BECAUSE THE VACUUM CANT BREATHE. TAKE IT TO YOUR LOCAL ORECK AND THEY CAN PUT A FEW HOLES IN YOUR SOLEPLATE AND THIS WILL TAKE CARE OF THE ISSUE.
Apr 02, 2013 | Oreck Magnesium Upright Vacuum Cleaner
Van does not stay running.
Yes, you have a fuel pump in the gas tank.
But, before you replace the pump, check the fuel pressure.
Mar 26, 2013 | AM Auto Parts 1997 to 1999 Ford E350 Van...
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
Aug 16, 2012 | Sharper Image Hybrid GP (SI724) Air...
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
CAR DIE WHEN SLOW DOWN OR STOP AND LET GO THE GAS
i went to my mechcanic the same day my engine started to make the same loud noise that you are talking about. he said that it was the flex pipe. just this morning (5:30am 8/3/09) i went to dunkin donuts for my morning coffee and while waiting in line, my car just stopped running. like you said, when you take your foot off the gas and press the break, the car stops. no doubt about it, it is the flex pipe. im sure by now you got your car fixed but i thought that i'd share my car troubles with you :)
Feb 12, 2009 | Blueair Blue Air 402 Smokestop Particle...
Purifier doesn't go on and keeps blowing fuses when turned on
If the machine keeps blowing fuses there is a short in the electrical circuit and it needs to be looked at by a certified repair center.
Make sure the fuses you replace are the same as the original
100,110 volt models use the 1.0 amp slow blow fuse
220 volt models use the 0.5 amp slow blow fuse.
I hope this helps
Eric
Jan 10, 2009 | Ecoquest Breeze AT Living Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Spectre 2006 Ford Econoline - E250, 4.6L V8 - Air Filter Logo
43 people viewed this question
Top Spectre Air Purifiers Experts
 Russ Hill
Russ Hill
Bill Boyd
Lawrence Oravetz
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
