Question about GE WSXH208A Front Load Washer
GE WCVH6430 Front Load Washer Loud Thumping plastic shavings Sloppy Loose springs?
Is there a way to tighten the springs for more tension? Always had problems now I found some plastic shavings that are foreign and I was told smoke at the end of the last spin. It still functions but on no spin still clanks loud but no more smoke. The drum is and always was sloppy or loose like it needs stronger springs.
  • 5 more comments
  • Dan Baldwin May 09, 2013
    It is a GE WCVH6400JOWW and a shock or damper thing was completely off, (thanks for the educated diagnostics) I got it back in place and found a long sliver of rubber and more shredded plastic. I tried another load and it was better but unstable from the damage caused. Any ideas as to what parts I will need, I know it is plastic and rubber.
  • Dan Baldwin May 10, 2013
    I am about to unscrew the front to see the extent of the damage, I will try to document the repair if its worth repairing and the cost of parts
    the 2 top springs were above there slot so i put them back taking the boot off was not easy how do I determine if the rear bearing needs replacement?
    Do I need a rubber thing ?
    Stephen Lam had it pinned! Here are some photos of his exact diagnostic
    Repair or Replace washer??? Will the boot be okay? should I look for more damage?
  • Dan Baldwin Jul 02, 2013
    My solution was to buy a new used machine. I took it apart and am selling good vital parts on EBAY I hope to get a few bucks back. This was a job for a pro but I gained knowledge and diagnostic rule of thumb for future issues. This problem has been solved not fixed this time.
4 Suggested Answers
  • 641 Answers
SOURCE: Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Posted on Jun 28, 2006
  • 670 Answers
SOURCE: I Have a GE washer and during the last spin I
You did not mention the model number of your washer, but you description leads me to believe that your washer is a front load washer. The problem you describe sounds like the spider arms that support the wash drum has failed and are broken. It is an expensive repair, and typically the cost to repair exceeds the price of a new washer. Get a few estimates, before deciding whether to repair or replace. Sorry.
Posted on Nov 03, 2010
  • 32 Answers
SOURCE: The whole drum assembly in my ge front load washer is loose and banging
Sound like the bearing on the back of the drum has failed. It's not too difficult to replace.
Posted on Sep 10, 2012
My machine is 2 months old and makes a horrible thumping noise during the spin cycle. Also the fabric softener compartment won't drain water
Ugh the thumping noise during spin may mean bad agitator spindle where the splines have been damaged or perhaps a damaged transmission spline, at other times it could be due to bad counter weights . check below
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 29, 2015 | Washing Machines
Thumping and banging during the high speed spin cycle
Feb 08, 2014 | Frigidaire Washing Machines
My GE GCVH6260FWW front load washer made a load snap while spinning. Repair man couldn't find anything. So we ran a load through and at the end of the wash cycle it started thumping and vibrating on high...
If the drum is also loose, it is dead. The plastic your are finding comes from a part inside. It will cost more (or close) to fix than to replace and you risk breaking other critical parts if you DYI.
Mar 01, 2011 | GE Energy Star WCVH6260F Front Load Washer
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
When washer is in spin cycle drum is out of balance.
REMOVE THE FRONT PANEL AND SEE IF ONE OF THE SPRINGS HAS BROKEN, COME OFF AND THE TENSION OF THE BELT OR THE TENSIONER PULLEY
Apr 09, 2009 | Frigidaire FWS933F Top Load Washer
Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
It is makeing a nose when it spins
If its a rattle could be a lose agitator
if front load then screeching or thumping is most likely out of round tub or wheels
top load thumps suspension springs
loud roars are always bearings
always give more details
model serial manufacture and top or front load
May 01, 2008 | Washing Machines
GE WSXH208A Front Load Washer Logo
176 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
