Question about Dell Dimension 4600 PC Desktop
Help with upgrading Dell Dimension 4600 GPU
So, I have A dell dimension 4600i. Recently My Graphics card has broken and I need a new one. I need to know which Good and Cheap Graphics card will be able to run on my PC. My Specs are: CPU - Intel Pentium 4, 2.8Ghz RAM - 1.5GB DDR1 CL3 Motherboard - Dell Dimension 4600i GPU - Intel 82865G Graphics Controller OLD GPU - nVidia Geforce FX 5200 OS - Windows XP SP3 Home Edition
  • Dell Master
  • 5,660 Answers
June,
The Dell Dimension 4100 Desktop PC, utilizes an AGP slot on the motherboard, for a graphics card.
http://en.community.dell.com/support-forums/desktop/f/3514/p/17152514/17275500.aspx
There are different styles of AGP expansion slots.
The one on your motherboard was the last current style of AGP -
AGP 8X
Therefore your Dimension 4100 uses an AGP 8X graphics card.
It is (Was) an Nvidia GeForce FX5200 graphics card, and the AGP 8X style.
http://en.wikipedia.org/wiki/AGP
To replace it just use a graphics card that is AGP 8X, and is better, or equivalent to the GeForce FX5200.
You also need to know that your Power Supply in your computer, will handle the power requirements for the computer system, AND your new found AGP 8X graphics card.
Power Supply was rated, at a maximum Wattage rating of 200 Watts.
Problem is; that back in the day when the Dimension 4100 was made, the Power Supply manufacturer 'Fudged' the real Wattage specifications.
Power was (Is) more like 60 to 70 percent of what is stated.
Divide 200 Watts by 10
= 20
Now take that times 6, for 60 percent.
= 120 Watts
Now take that times 70, for 70 percent.
= 140 Watts
ACTUAL power
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410189&CatId=2234
I would recommend this one, but it requires 250 Watts MINIMUM,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
[Graphics card manufacturers, base the Minimum power requirements for their graphics cards; based on a test computer system.
So the Minimum power requirement stated, is not only for the graphics card; but ALSO the rest of the computer.
The test computer system is usually based, on all of the top of the line, power consuming hardware components; of that time
Top of the line powerful Processors, and Motherboards.
Add to that the maximum amount of Ram Memory, that can be used.
Two optical drives, (CD/DVD drive)
Processor fan, and at least two computer case fans ]
KNOW THIS:
A) FOLLOW Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, and BEFORE taking any new parts out of their Anti-Static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return
B) Windows running on your computer, PUT the Installation disk that comes with the graphics card, in your optical drive tray.
(CD/DVD drive)
Install ALL software.
There will be Drivers you are installing, and also a graphical user interface. (GUI)
The GUI for an Nvidia graphics card, (Evga GeForce 6200 is an Nvidia card), is the Nvidia Control Panel.
(For ATI it's Catalyst Control Center)
Driver: Small piece of software that allows the Operating System to communicate with a device
In this case the device is the graphics card.
What version of Windows operating system was not stated.
-> AFTER <- you have installed the software, and if it asks you do you wish to restart your computer; the answer is -> NO
Close all windows, go back to your desktop screen.
Now turn the computer off normally.
Follow Anti-Static Procedures, and Physically install the graphics card.
Note*
The AGP expansion slot on the motherboard, will have a type of Locking Arm on it. With most the end of the arm, has a 'fingerdip' in it.
Makes it look as though you press DOWN, on the end of the Locking Arm, in order to release it. (Unlock)
Actually you GENTLY pull up a little on the PLASTIC Locking Arm, to release it.
Release to remove the old graphics card, and to install the new one.
After the new graphics card is installed, attach the monitor cable to it, and close the computer case.
Turn the computer on.
You MAY have to go into the Nvidia Control Panel, and set Screen resolution, and other parameters.
(Look up your monitor by it's manufacturer name, and model number. {Back of monitor - Model Number}
See what the Screen resolution is.
Example - 1280 x 800 pixels
Set Color quality to High (32 bit)
Have additional questions please post in a Comment, or Reply.
(Below my solution)
[When a device is installed on a computer with Windows, Windows will 'break it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = NO
A Driver Conflict can result.
Windows: "Which drivers do I use? These or THESE?"
With THE drivers installed first, Windows will find them.
Posted on May 06, 2013
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: I have a dell dimension 4600i. I want to upgrade
The Dell N2828 motherboard is supposed to have the Intel 865PE motherboard chipset on it.
http://www.ascendtech.us/itemdesc.asp?ic=MB4DEL2Y832&eq=&Tp
Looking at the - List of Intel Chipsets - on Wikipedia, we can see that the maximum FSB supported is 800MHz,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
[Scroll down with your eyes to 865PE, then read across ]
Dell Support lists that the Dell Dimension 4600 series, can have either the Intel 845G motherboard chipset, or the Intel 845PE motherboard chipset.
As seen in the chart the Intel 865G motherboard chipset, also supports up to an 800MegaHertz Front Side Bus.
The processor socket is a Socket 478.
I see that Weirdstuff.com, (Surplus warehouse) has Pentium 4's available with an 800MHz FSB.
Looks like the best they have is a Pentium 4 at 2.60GHz, 512MB cache, 800MHz FSB for $18.95 (US. They're located in California)
Not advertising for them, just sharing,
http://www.weirdstuff.com/cgi-bin/category/CPU000
Scroll way down the list to the heading - Socket 423/478 (Pentium 4/Celeron), then go towards the last of the list.
[To expound:
The motherboard chipset is the Northbridge/Southbridge chipset.
Chip and Chipset are slang terms for I.C., or Integrated Circuit.
This motherboard diagram, may help explain how the motherboard chipset comes into play,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
You can also look up the terms listed, by typing them into the Wikipedia search box, then clicking on Search.
You may be interested in looking up;
1) Northbridge (computing)
2) Southbridge (computing)
3) Front Side Bus
4) Internal Bus
5) Super I/O
6) Comparison of Nvidia Chipsets
7) Comparison of AMD chipsets
8) SDRAM
9) PCI Local Bus
10) PCI Express
11) GPU
12) Comparison of AMD graphics processing units
13) Comparison of Nvidia graphics processing units
14) Intel GMA ]
Anything listed in blue, is a link to more information about it. Just left-click on it.
As you can see in the chart, the Northbridge chip handles the high speed processes of a computer.
Such as the Processor, Ram Memory, and high speed graphics.
AGP and PCI Express being high speed graphics. Any graphics card inserted into a PCI slot is Not high speed graphics.
The Southbridge chip handles the slower processes of a computer.
Anything to do with PCI, or Integrated Graphics, being two of the slower processes.
Therefore if you know what Northbridge chip you have on the motherboard, and what processor socket, you are pretty well on your way to know what processors your motherboard supports.
The Northbridge chip is under that 'meat cleaver' looking heatsink next to the processor socket.
If the heatsink were removed, and any thermal paste also removed, you would see - Intel 82865PE stamped on it.
Not a good idea to remove the heatsink, without having fresh thermal paste to replace the old thermal paste with, PLUS the top of the Northbridge chip, And the bottom of the heatsink needs to be THOROUGHLY cleaned Before applying new, fresh thermal paste.
The Southbridge chip has Intel ICH5, or ICH5R on it.
Posted on Apr 28, 2010
joecoolvette
  • 5660 Answers
SOURCE: Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 14, 2012
jadiazq
  • 2878 Answers
SOURCE: dell dimension 4600 problem with nvidia gforce fx 5200 card
Very broad problem. You can re-seat card, or use a different slot if possible. You can test card on another PC. You can wipe PC and do a clean install. This may be the surest way to determine if the the card is bad or driver conflict with OS.
Posted on Nov 22, 2012
Previous fan failure
? I'm not sure what your question is, but replacing the fan on a dell dimension is pretty easy.
Here are the instructions: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1139391
And heres a link to buy one off of amazon: http://www.amazon.com/Dell-K0456-Assembly-Dimension-OptiPlex/dp/B000MME1TW
Dec 30, 2011 | Dell Dimension 4600 PC Desktop
I need to replace a network card in my Dell Dimension 4600. I already have the new card. It came w/ a driver CD but no other instructions. What is the proper procedure to replace this and have the PC...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please clcik on the below link that has the steps for the physical replacement of the card
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1116421
once done you need to install the drivers for the lan card and then you should be able to get online
let me know in case you have any queries
Nov 22, 2010 | Dell Dimension 4600C PC Desktop
I need to install a memory card and want to know how to remove the side cover on the pc desktop
ehjh
If you go to this link it will show you how to open the side panel on your Dimension 4600.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/cvrop.htm#1138085
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Dell Dimension 4600 PC Desktop
It should.. Here is a link to documentation.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/specs.htm
Apr 28, 2010 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 what kind of motherboard do i have.
Your Dell Dimension 4600 comes with an Intel motherboard with the Intel 865PE or 865G chipset running an Intel P4 class processor.
Here are the specifications for your machine and motherboard:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Mar 07, 2010 | Dell Dimension 4600 PC Desktop
How do i open my Dell dimensions 4600 to install
Just lay it over on its right hand side, there a button on the top and the bottom, press these both at once and lift. It will just hinge up and give you plenty of access. When closing just make sure its lined up and it simply clicks back into place. Cheers from Scott
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600 creative sound blaster card
It sounds like you may have broken your sound card. I had the same problem when I tried to digitise my old 4-track recordings.
I tried the broken card in another PC, found that it was not working, so I went out and bought a new sound card.
Apr 06, 2009 | Dell Dimension 4600 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
95 people viewed this question
Alun Cox
