Question about Music
Korg gt-6 guitar tuner Mic wire repair - Music
2 Suggested Answers
SOURCE: Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Posted on Mar 12, 2010
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
My Korg DT-10 Tuner is broken. I think it is the power supply. Do you think it is cheaper to repair it or should I just get a new one?
if your pretty sure its a crack in the circuit board from dropping or rough treatment then yes it can be repaired in less than an hour-contact a guitar repair center to see who does there electronics repairs they might take that on if asked , but if it just started to do this with out a known cause its most likely a component failure and that will take some time and knowledge to find cause and repair , on this unit that might not be feasible to do
Feb 29, 2016 | Korg DT-10 Digital Tuner
How to tune 12 string acoustic with ga40
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
How to tune 12 string guitar with ga40
Just use as if you are doing a 6 string ( instructions in the pack ) only play one string in each group at a time. The thinner string in a pair should be exactly one octave higher than the thicker string. Strings of the same thickness are in unison ( sound the same pitch )
I tune my bass guitars on the tuner no problem, i have recently tried to tune an electric guitar, but the tuner locks up... any suggestions please.... Thanks ... J
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Jul 05, 2011 | Korg GB-1 Pitchjack Plug-In Guitar and...
How can I tune mas bass guitar to A=444hz with a KORG GA-40 ???
You turn it on and there are the two buttons under the power on button. These ratchet the base frequency up and down. In the upper left corner of the display you will see what A is currently tuned to in tiny characters.
Mar 22, 2011 | Korg Ga40 Guitar Bass Tuner W Batteries
Any way to sever the "bypass" connection from either the "A" or "B" input? Scenario would be an Electric Guitar in input "A", which passes it's signal out the...
Just use WYE connectors and run each guitar to their destination without using the bypass output of the tuner at all... Each guitar into a WYE into the tuner and then continue to the amp and DI box.
Mar 19, 2011 | Korg Pb02 Pitchblack+ Advanced Chromatic...
Have no idea how to use it
I can't find info other than the tuner has three lights for flat on, and sharp.
given that you would plug it in and do a close tune of the guitar by ear.
Then you would strum one string at a time and tweek the peg tighter if it shows flat, looser if it shows sharp, until it shows the light right on.
I would recommend you get a book on guitars to learn how to tune and also check the setup of the guitar.
Also I would recommend you get a Korg tuner... they are about $20 from online sources and they are much easier to use.
Feb 20, 2010 | Music
Jan 05, 2010 | Music
Music Logo
41 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
