Question about Halex Millenia 1.0 Electronic Dart Board
How can I replace a lost AC adapter? Item #100-64671-300MA,small jack.
Toshiba laptop will not turn on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Mar 01, 2013 | Computers & Internet
My HP laptop will not turn of even when plugged in
Possible causes:
Feb 22, 2013 | HP Pavilion Computers & Internet
Asus laptop won't power on
Possible causes:
Dec 21, 2012 | Computers & Internet
Dell vostro a840 won't start
Possible causes:
1.Dell Vostro A840 AC adapter failure.
Dec 18, 2012 | Dell Computers & Internet
Acer 4320 won't power up
Possible causes:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
Why won't my gateway MD78 power on?
Possible causes:
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
Mini dell 910, no power
Possible causes:
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
My hp netbook wont turn on, what shoud i do?..
Possible causes:
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Possible troubleshooting steps and repair solution:
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Halex Millenia 1.0 Electronic Dart Board Logo
139 people viewed this question
Top Halex Sport & Outdoor - Others Experts
Are you a Halex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
