Question about Video Cameras
HP ipaq How to repair touch screen issue on motherboard, I have check the lcd with a same model motherboard, It is work fine, After that Idetified problem in the motherboard, Please reply me. Thank you
  • 4 Answers
Please call the company service person if it is on warranty. He will help you out. .Also check for the latest motherboard driver and install it.
Posted on Jul 06, 2013
3 Suggested Answers
quang123
  • 107 Answers
SOURCE: touch screen problem
Please see the solutions on the same model I posted earlier
Posted on Dec 09, 2008
SOURCE: HDR-SR12 - LCD Touch screen not working.
My camera's touch screen on my SR12E also stopped working early this month (July 2010). Just before I had had it for two years.
I tried to backup, and was really struggling since most functions are done via "the touch of the screen".
But after much frustration trying, I found out that the camera also connects to the laptop the same way by pushing the "burn to disk" button. Try also the blue "EASY" button if the other do not work.
When this is done you can start the "SONY program" to choose import media or what it is called inside the program...
Now you will get the normal menu "popping up" so you can choose to backup the content to your computer.
Beware:
What I did further after backing up was to push the "reset" button to try to maybe get the "touch screen function" back in order.
But this only resets all preferences for the camera.
It did not delete what was stored on it.
The result is now that I will have to film in "default mode" (low quality) for the rest of my holidays, and get an irritating "set-up" screen menu prompting me to input the date etc each time I start the camera and at other intervals...
So the rest of my holiday will be in SD and not HD...
It should have been possible to choose the selections (navigate the camera) via your laptop when you end up in a situation like this...and need to change my settings.
Hope my solution were helpful for being able to backup.
I think you still should check with "consumer help" in your country if you can still get a free repair when the screen stops working, since you normally will be more extensively protected by law then what the warranty tell you.
Posted on Jul 26, 2010
Hx2415 stuck on align screen
i think you have a problem with you touch screen digitizer. you can send your device to a repair center to replace the TP only, without the need od replacing the entire LCM display panel.
A touch panel withou the lCD should cost much less than an LCD.
Jul 30, 2009 | HP iPAQ HX2490 Pocket PC
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
Feb 17, 2009 | HP iPAQ RX3115 Pocket PC
Changed screen, now no power
Disassembly and assembly it again, putting close attention to how the mainboard is assembled, and all the wires and connectors are placed.
If the switch that senses when the rear cover lid is not working fine, won't power on.
If during the assembly of the PDA you had by accident something that prevents the swithc to work, you will have the problem.
You have to check also the contacts for the battery on the ain board. Check that are not damaged, bent or desoldered.
Other possible reason is that during the repair of the LCD screen, the mainboard was forced, bent or warped, then you will have a more serious problem, since tiny smt capacitors are cracked very easy, which causes an electrical short, preventing the PDA to power on.
Diagnosctics and repair of it needs a qualified technician for it.
Best regards,
Oct 08, 2008 | HP iPAQ RX3115 Pocket PC
ALING DISPLAY CYCLICAL PROBLEM
Best regards,
Apr 03, 2008 | HP iPAQ RX3715 Pocket PC
Ipaq problem
Best regards,
Mar 31, 2008 | HP iPAQ RX3715 Pocket PC
IPAQ rx3115 continuously, "screen alignment",
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3115 (or RX3715) PDAs.
Best regards,
Feb 26, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Screen not responding to touch
Solved same problem.
Same model ipaq 1940.
Sorry for my bad english;this is what You can do:
Open the ipaq
Remove the mainboard
My problem was the connection between LCD and Touchscreen.
So I solved putting on the connection 3cm of tape to have a fully working contact.Indeed, the lower part of cable, with the 2 little holes was disconnected.
After this all becames to life!
I hope helps!
Vit :-)
In italiano: 3 cm di nastro adesivo fra LCD e touchscreen.Il loro contatto non era perfetto.Ora tutto funziona.Con un po' di manualità si riesce a fare senza problemi!
Saluti, Vit
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Feb 25, 2007 | LG 37LP1D 37 in. LCD Television
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
