Question about Kenneth Cole New York Automatic Bracelet Watch for Men
Kenneth cole watch
The set screw for the pin that holds the bracelet to the watch base has come out and is not to be found. How can I obtain a replacement set screw?
    Problem Solver:
  • 20 Answers
Many jeweler have drawers full of spare parts like that. watchmakers too. if you strike out at a jeweler, ask who they use to service their watches.
Posted on May 11, 2013
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: How do I shorten watch bracelet?
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Don't forget to rate, please.
Posted on Jan 21, 2009
escapement
  • 2334 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
How can I obtain a the bracelet pin that holds the bracelet to the watch base? I currently have the pin but have had the set screw that holds the pin to the watch base come and is lost.
Well if its a spring-bar you're looking for you can generally find assorted sets fairly cheap on ebay....if you need a screw pin you could try ebay or possibly a radio-shack? I think I've found smaller screws there before generally used in small electronics.
May 06, 2013 | Kenneth Cole KC3485 Wrist Watch
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
How do I remove link in kenneth cole new york watch
Check my tips and tricks. Watch band is called bracelet as well.
Jan 23, 2010 | Kenneth Cole Watches
Job done!
Jan 21, 2009 | Kenneth Cole KC3485 Wrist Watch
Job done!
Hope it'll help.
Regards
Arthur
Dec 15, 2008 | Kenneth Cole 1213 Wrist Watch
Wristband too big
Job done!
Dec 02, 2008 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole KC3754
Oct 27, 2007 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole Reaction band
Call 7298600 x 272 ask for a free pin for model rk 5033
Aug 27, 2007 | Kenneth Cole RK5034 REACTION
Kenneth Cole New York Automatic Bracelet Watch for Men Logo
74 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
