Question about AO Smith Pool & Spa
Unable to turn on
Nothing happens when I push the on button. It makes no sound; don't think it is making contact with motor. Can I check the power button from the top o the tub? The installer tiled in the tub and left no access panel.
  • 717 Answers
First, make sure the circuit breaker is on and there is power to the motor.
If you have power to the motor it may be that the air switch on the motor is not working and needs to be changed.
The air switch is around $21 to replace.
Rod @ US Parts Center
Posted on May 13, 2013
Ian  Hot Tub
  • 77 Answers
SOURCE: hot tub pump flo-master hp suddenly wont start.
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 20, 2010
aquaman987
  • 927 Answers
SOURCE: i have an aqua flow
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Posted on Aug 02, 2011
MOTORWIZJ
  • 1339 Answers
SOURCE: Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Posted on Dec 28, 2011
  • 111 Answers
SOURCE: I have power but the lights and pumps do not work when I push the control panel buttons
When you unplug & reconnect the topside control what happens?
If nothing your control is bad, you'll need a new one.
They are typically attached with double sided tape so removal is easy.
Posted on Nov 14, 2012
uspartscente
  • 717 Answers
SOURCE: hot tub jets won't come on. Backlight on topside works and shows current temp. but jets or led lights in tub won't work. Topside panel buttons are dead. What is problem? Viking Royale spa
This sounds like a back circuit board to us.
rod
uspartscenter.com
Posted on Apr 09, 2013
My LG Tromm dryer makes 3 clicking sounds when I push the start button. Everything lights up as if it is going to work, but when "start" is pushed, I just hear the 3 clicks and then nothing happens
If the drum doesn't turn, check the centrifugal switch on the motor shaft. Check if the belt hasn't broken or if it's off the motor shaft.
Jul 16, 2014 | Dryers
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
I used to have to push the 'start' button several times to get it to start the wash cycle, now...nothing happens at all? any ideas?
Sounds like your control panel is going out on you. It is not communicating at 100% to the rest of the unit. Contact your manufacturer and one of their service companies.
Aug 22, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
Coleman powermate compressor wont start. It has always ran fine. Went out and the tank has no pressure. Everything looks Ok, but it wont start. Doesnt even make a sound. There is power at the plug in. ...
Two main things to check are the motor circuit breaker and pressure switch. Without knowing your model number I don't know exactly where to tell you to look but somewhere on the electric motor, or plastic housing if it's remotely mounted, there should be a reset switch/button. They are usually red or white, sometimes black. Push it in and see if the motor works. If the breaker keeps popping off there is something making the motor work too hard like bad bearings in the motor or pump, piston/cylinder issues, etc. To check the pressure switch, unplug the cord or turn off the circuit breaker. Remove the cover on the pressure switch and find the wires from the cord and motor. You can jump them on the switch (black to black & white to white) or disconnect them and connect the two black wires together and two white wires together. Turn on the power and if the motor turns on it's the switch if not it may be that your motor is burnt up inside. Don't let it continue to run like this because it will overfill the tank to dangerous levels without the pressure switch wired in.
Jan 28, 2012 | Coleman Powermate 27 Gallon Air Compressor
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
The 4 wheel drive doesn't work in my 89 Ford Bronco
The sound is not coming from the glove compartment, it is coming from the panel behind the drivers seat, that's where the relays and computer are located.
The relays click and apply power to a transfer case motor.
The motor attempts to turn a shaft that engages the front drive shaft.
When the computer thinks the shaft has NOT turned it tries again.
It will try three times then quit, figuring the shaft has not turned.
Get someone to crawl under the vehicle and engage the 4WD (just turn on the ignition- do not start the engine) See if they can hear the motor attempt to turn the shaft, it will make a clicking sound.
If not the connections or the motor may be bad.
I have found the most probable cause is the relays on the control board.
If you are technically adept --
you can remove the small side panel from behind the drivers seat and remove the control board. (remove the power plugs first)
Clean the relay contacts and bend them a little to give them more 'wipe' to keep them clean longer.
Put it back in and turn on the ignition.
Then push the RESET button on the side of the board.
Try the in / out 4WD a couple of times. If it doesn't work turn off the ignition, turn it back on and push the reset button again.
Oct 16, 2008 | 1989 Ford Bronco II
Pool & Spa Logo
101 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
