Question about Acer Aspire 3680 Laptop
Randomly shuts down
When playing online games laptop shuts down after clearing the fan
  • Acer Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on May 09, 2013
4 Suggested Answers
treborswindl
  • 212 Answers
SOURCE: My acer aspire 4315 laptop shut down unexpectedly
Sounds like hardware failure. Chek if it is under warranty. Good Luck.
Posted on Nov 20, 2009
Geekman
  • 32281 Answers
SOURCE: my laptop suddenly shut down when playing game..
If the laptop shuts down and won't boot up again until it has cooled down, then the laptop is overheating and causes the CPU to shutdown. If this fault is not fixed then eventually the CPU will fail.
The fan may not be covered with dust, but did you check the heat-sink?
The heat-sink fins maybe clogged with dust.
Check the fan, does it spin freely, if not the fan maybe faulty and needs to be replaces.
Posted on Mar 12, 2010
naren989
  • 50 Answers
SOURCE: computer sudden shut down while playing games and
I want you to make sure that you dont see any message(Not Error) when you turn on your Laptop.
If it displays "The last shutdown was due to overheat(Thermal Heat).
if this is the case, it means that your processor is being used to the atmost. If this happens, inorder not to harm your processor, the computer will be shut down abruptly. Actually, we have a Cool Sink Cream between the Processor and the fan just above the processor.
if the Cool sink cream is dried up, or dripped away, the processor cant distribute the heat to the heat taker.
so, the processor cant resist itself from being heated.
Even you dont see this message, this issue could be of the similar problem.
We may not resolve this from home, but we can follow a workaround.
when you use your laptop, allow some air to flow under/beneath the laptop, so that it might not get heated that much earlier.
Also, we buy and fix a cooling fan set for the laptop to keep it kool all the time we use or we can put it on some book or in some hight in such a way that the air openings under the laptop are not covered and the openings can take air.
If you still dont see any change, you can contact the Service Center to get the unit serviced.
Hope this helps.
Posted on Jul 28, 2010
My laptop is randomly shutting down.
check laptop randomly shdn:
software
1) renew windows system
2) clear virus
hardware
1) change adapter or battery
2) check or soldering DC lack
3) over heating, clean cpu fan dust
4) hard disk o sector issue, change HDD
Jan 01, 2014 | ASUS X44H-BD2GS 14in Laptop i3 2.2GHz 4GB...
My laptop (lenovo g560) randomly shut down.
Try scanning your computer with radarsync to know which drivers are out-of-date. It has something to do with the device drivers for sure. Update the drivers using RadarSync.
If it still not going to fix the problem then check if there's a sign of overheating after it shuts down. You might want to get it opened by a technician so that he or she can clean the air passages and fans inside your computer.
David
Jun 30, 2013 | Lenovo G560 06793JU Notebook
Randomly turns off when playing games
temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
May 06, 2013 | Acer Aspire 5542 Notebook
Overheating motherbord
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 03, 2013 | Computers & Internet
Acer latop shuts off randomly while playing bejeweled on facebook
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 03, 2012 | Acer Aspire 5735 Notebook
How do i resolve the auto shutdown problem when playing games?
Jun 03, 2012 | MSI EX465 Notebook
Laptop just randomly shuts off
Probably overheating. Are you playing games when it shuts off?
Turn the laptop off, remove the bottom cover, blow compressed air from a compressed air can to remove dust and lint. Check that the fan can move easily. Replace the cover. Restart the laptop. Download Hardware Monitor from http://www.cpuid.com/hwmonitor.php and install. Run the program and check for CPU temp. It should never be higher than 85 C when heavy gaming or calculations are running. If temp gets to 95-100 C, Windows and or the CPU will shut down automatically to protect the CPU and laptop from any damage. As far as I know, there is no way to disable this feature.
Apr 01, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop randomly shuts down
This problem might be occur due to old BIOS version installed on the laptop.
If your system shut down unexpectedly within 10-20 minutes while playing games or scanning the system which takes high cpu usages then the problem is of BIOS and try to install the new BIOS version.
for that visit the site of your laptop company.
Nov 25, 2009 | Computers & Internet
Toshiba a30 laptop over heating problems
It is obvious that your computer shutdown because it is overheating. try to get a chill mat to place it under computer. you said that it does not shut down when is on battery??? do you play games when is on battery?....computers normally overheat during large processing tasks such us playing video games. Try to fans clear do not place your laptop ontop of your bed or anything that will obstruct the fan under computer.
See if that works
best luck
Apr 10, 2009 | Toshiba Satellite Pro A30 Notebook
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 3680 Laptop Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
