Question about Briggs & Stratton Garden
Primer bulb broken(in fact the rubber is broken)can you please tell me how to change the rubber part? and also the throttle doesnt functioning properly( only maximum)
  • 97 Answers
Look in where the bulb goes into the shroud. There will be a snap ring in there. just remove the snap ring and the bulb will come out. Make sure you replace the snap ring and check the hose to the carb.
Posted on Dec 28, 2013
  • 376 Answers
SOURCE: 158cc yard machine, starts then dies.
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
Posted on May 26, 2009
  • 376 Answers
SOURCE: 7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
Posted on May 31, 2009
carlsbiz
  • 1124 Answers
SOURCE: engine will not stay running,after priming it
First things to try is -
Clean the air filter..
Replace the spark plug..
Posted on Aug 31, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I replace primer bulb on mountfield SP470
I believe this mower has a Briggs & Stratton engine, if that is the case:
Look at the base of the primer bulb where it is mounted on the carburetor, you will see an opening on both sides of the plastic that the bulb is mounted in where the locking tabs are.
Take two small screwdrivers, press in on the tabs and pry toward the outside of the housing at the same time to release the tabs and bulb. Pull the entire bulb and mounting ring out as an assembly. Don't worry too much about damaging the ring, a new one should come with the new bulb, in fact, it would be wise to purchase the new bulb prior to beginning so you can see what you are working on
Posted on Nov 03, 2009
Testimonial: "Many thanks for your expert advice, as soon as the weather picks up I will replace said primer bulb. "
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
Primer bulb
Hi Bob McDonnell....
Here is how your fuel should be routed...
Please rate me
Bud
Sep 26, 2012 | Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Primer bulb will not remain full. Blower will start but dies when throttle is used. Appears to be leaking air around the grommet to the fuel tank.
you should maybe change grommets/pipes to the fuel tank,also the primer bulb maybe is not working properly,consider changing the primer bulb,rgds
Sep 25, 2010 | Echo Garden
I REPLACED THE PRIMER BULB AND NOW THE TRIMMER WILL NOT IDLE UNLESS IT IS AT FULL THROTTLE
Try swapping the hoses at the primer bulb. You may have put the return hose on the purge side of the primer bulb.
Sep 04, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I am replacing a primer bulb in a chainsaw and the lines are gone so i need to find out which line goes where
Leave both primer ports open, then attach the fuel line that feeds the carburetor from the fuel filter to one of the primer ports--pump the primer and if you guessed correctly, it should pump fuel into the primer bulb. That is the primer port that goes to the carburetor output connection. The other primer port connects to a short line that goes back into the fuel tank with no filter. Return the original feed line back to the upper carburetor port. Connect the open primer port to a short line that connects to the carburetor lower port. Be sure to use original rubber lines, not plastic. Hope this helps!
Jun 22, 2010 | Garden
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
How to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Toro Lawn Mower With Toro Power Tools
Need diagram/instructions on how to replace primer bulb on briggs and stratton push lawn mower My primer bulb has busted so I'm trying to replace. Don't know how to get the old one out and replace.
Unless they have changed, all you have to do is unscrew the old primer bulb and screw the new one on in it's place. The primer is composed of the rubber bulb with a metal or plastic ring with threads on it where it connects in the fuel system.
Jul 17, 2009 | Garden
Primer Button
This part is sold as an assembly Part# 530038874
Undo the screws holding the primer and note the fuel line location
as the new one will be identical.
Note the long and short tube connection under the primer bulb itself and the designated tube for each
Jun 04, 2009 | Garden
Garden Logo
59 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
