Question about Acer TravelMate 5760 156 500GB 4G (AAC4001TM57606662
Reset bios 4052lci cmos 2310 - Acer TravelMate 5760 156 500GB 4G (AAC4001TM57606662
  • Acer Master
  • 27,725 Answers
Your computer's BIOS screen can be incredibly useful when you need to make certain hardware or system configurations.
How to access the BIOS on your laptop varies from manufacturer to manufacturer and model to model.
Even though Acer laptops are created by the same manufacturer, not all models access BIOS in the same manner.
While accessing the BIOS setup screen in and of itself is not difficult all you need to do is press a key the difficulty is in figuring out which key to hit.
Restart or power on the laptop.
Hit the "Pause/Break" key the moment the Acer boot screen (not the OS start-up screen) appears.
If the OS start-up screen appears before you can hit Pause/Break, you will need to restart the laptop.
Press "F2" or "Del" to access the BIOS set-up screen.
Depending on the age of your Acer laptop, you may need to instead press "Ctrl," "Alt" and "Esc" simultaneously to access BIOS.
Using the arrow keys navigate failsafe or optimized defaults press F10 to safe to cmos and exit to restart.
Posted on May 09, 2013
How to baypass bios password on sumsung np300e5x
You can't bypass BIOS password. All you can do is to RESET BIOS, by removing CMOS battery and waiting some time till it discharges completely.
After you reset BIOS, you shuld enter BIOS at startup and input your setup values, so before doing this, you should check your BIOS setup. See some video tutorials but be careful. Dismounting a Laptop is not a joke. You may end with some parts in a shoebox rushing to your repair service...
How to reset BIOS on laptop
How to remove Hard Drive and CMOS Battery from an HP Compaq 6735b Laptop
Reset Clear CMOS on Laptop and Desktop Tutorial 2015
Tutorial How to replace the CMOS battery in your laptop
Jul 24, 2015 | Computers & Internet
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
Tip
How to reset or remove BIOS password
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.<br /> <br /><b>Manufacturer Backdoor BIOS Password</b><br /><br />Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI, IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing. <br /><br /><b>Reset the jumper that holds the password<br /></b><br />Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.<br /><br /><b>Removing the CMOS Battery to reset the BIOS to default</b><br /><br />Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now. <br /><br /><b>Using third party software utility to reset BIOS password</b><br /><br />To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website <a href="http://www.hirensbootcd.org/">http://www.hirensbootcd.org/</a>. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
on Dec 12, 2010 | Computers & Internet
What is BIOS password?
No way to know YOUR bios password.
If you've neverassigned a BIOS password, press enter without inputting anything.
If you have a BIOS passwoed, you can reset BIOS rmoving CMOS battery
laptop cmos battery
How to Clear Your Computers CMOS to Reset BIOS Settings
How to clear an unknown BIOS or CMOS password
Apr 01, 2015 | Computers & Internet
Resetting cmos
The best way to RESET the BIOS back to the factory defaults if you do not know the Reset jumper or there isn't one is to remove the CMOS/BIOS battery and wait for approx. 20 mins for the charge in the BIOS to discharge.
If you cannot wait that long then short out the battery terminals on the motherboard with a paper clip.
Replace the BIOS battery, go into the BIOS setting and set the date and time etc.
May 23, 2012 | Computers & Internet
Tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 | Computers & Internet
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
I have a Wipro Laptop. His BIOS is Phoenix. It has a CMOS password. How shall I clear the password.\?
Hi Nayanranjani.
As you trying to reset the BIOS password, let me provide the required steps.
You may reset the BIOS password by just removing and inserting the CMOS Battery.
The CMOS Battery will have the Computer date, time and also the BIOS password saved in it.
Hence, removing and re-inserting the CMOS password will reset the BIOS password.
Once the BIOS password is removed, you may assign a new BIOS password.
Hope this helps.
Please feel free to ask further questions.
Aug 18, 2010 | Computers & Internet
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
Acer TravelMate 5760 156 500GB 4G (AAC4001TM57606662 Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
