Question about Dell Inspiron 530 Desktop Computer
Changed Voltage on DELL INSPIRON 530 and BANG.
I received a new computer and the red slider was half way across i pushed it to one side (stupidly when powered up) and it made a loud bang and lost all power and it tripped the breaker. What will be the damage to it? How can I fix it?
  • Dell Master
  • 1,684 Answers
The power supply unit should be the only casualty. If it is new then Dell may cover it under warranty. Do not tell them about the slider, just say it popped when you powered it up. If the unit is not under warranty them you will need to get a replacement power supply, they are available on Ebay for around $40
Posted on May 06, 2013
gcrcomputers
  • 170 Answers
SOURCE: looking for a dell 650w power supply part#AA23390
Here you go....
Nice price too...
http://www.serversupply.com/DELL/POWER%20SUPPLY/DESKTOP%20POWER%20SUPPLY/650%20Watt/AA23390.htm
If this helps please rate my solution accordingly,
Thanks,
david
Posted on Mar 18, 2009
gurutim
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
gpcomputer01
  • 137 Answers
SOURCE: My Dell Inspiron 530 wont turn on
yes buy a power supply. I have seen hundreds of computers that have gone through storms. Remember a Dell usually uses a special power supply.
For a good deal look on ebay for your specific model, They almost always have "Buy it Now" deals.
Posted on Aug 15, 2009
SOURCE: Turning on DELL 530 the orange led remains on
I'll save you 3 hours on the phone with DELL. Same problem.
If you are OK with this, turn power off, discharge system by pressing on button for 5 seconds. Identify the slot for the phone jack/modem. Remove it. Plug in and turn on. If that is the problem, turn off and insert the card in the adjacent slot. They asked that I replace the motherboard, so if you're under warranty, call them.
Posted on Dec 10, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
How to hook up keyboard to my dell Inspiron 530
Keyboard come with two different connection options these days. The old PS2-style (circular with ~5 pins) port are less common on current machines these days. The Dell Inspiron 530 is one of them; you need a USB keyboard or a PS2 to USB adapter. This adapter, http://www.amazon.com/Adesso-Adapter-connects-connectors-ADP-PU21/dp/B00008ZPED , is an example of how you would connect your old keyboard to your new computer. There are USB ports on the front and back of the tower.
If you bought the computer new, it should have come with a USB keyboard.
I hope this helps.
Feb 24, 2013 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 beeps 6 times when turned on and doesnt start. The fan runs during this process untill the beeps. Tried unplugging everything and then just the monitor and tower, same result.
you have to reseat the memory
Reseat means you have to remove the memory while the computer is unplug from the system
1. Unplug the power cable from the system
2. Press the Power button for about 5-10 secs to drain any electro static discharge
3. Locate the memory bay
Theres 2 white clips in each side
you have to press the 2 white clips on each side to remove it
if you 2 memory you have to remove both of them then put it back the way it was removed and push it towards the slot like you see in the picture.
you must heat that it clicks , thats the indicator that its properly seated.
please be careful and do not put too much pressure when pushing/pressing it down.
Hope that helps
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
Cannot Print from Dell 530 Inspiron w/Home Vista
Try this:
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
May 16, 2010 | Dell Inspiron 530s Desktop Computer
I have just changed over to a new Dell computer- Inspiron 530
I know Radio shack is a bit pricey but they have these for a few bucks. Or Ebay has them if you know which one you need. good luck
Jul 13, 2009 | Dell Inspiron 530 Desktop Computer...
Old speakers will not work with new Dell Inspiron 530
Speakers are pretty much universal. Plug them in, and connect the audio cable to the green receptacle on the computer.
Apr 05, 2009 | Dell Inspiron 530s Desktop Computer...
SOUND PROBLEM
You shold download and install this driver : http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Dell-Inspiron-530-Realtek-HD-Audio-Driver.shtml
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 02, 2009 | Dell Inspiron 530 Desktop Computer
Voltage limits
are you talking about the powersupply? open the case of the computer, the powersupply reads all this information on the side.
Feb 18, 2009 | Dell Inspiron 530 Desktop Computer
Getting a manual
Use this link download varies manual concerning to system
http://searchapj.dell.com/results.aspx?s=dhs&c=in&l=en&cs=indhs1&k=Dell+530+Inspiron+manual&cat=all
the above will give below information on the site
Appendix: Dell Inspiron 530 Owner's Manual ... Appendix Dell Inspiron 530 Owner's Manual Specifications ...Cleaning Your Computer Dell Technical Support Policy (U... Product name: Dell Inspiron 530 Model number: ... Setting Up and Using Your Computer: Dell Inspiron 530 Owner's Manua... ...Using Your Computer Dell Inspiron 530 Owner's Manual Front View of the Computer...your computer when you access the Dell Support website or call technical...specifications indicated in this Owner's Manual reflects the maximum ambient operating... Glossary: Dell Inspiron 530 Owner's Manual ... Glossary Dell Inspiron 530 Owner's Manual Terms in this Glossary...code located on a sticker on your Dell computer. Use the Express Service Code when contacting Dell for assistance. Express Service...
May 25, 2008 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
mukhtar21 shaikh
mukhtar21 shaikh
