Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
(C-0500) error code konica di 470
How I can cancel (C-0500) error code for konica di470 ?! I replaced Fuser roll and fingers.
  • Konica Minolta Expert
  • 1,326 Answers
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
Posted on May 07, 2013
4 Suggested Answers
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
  • 14 Answers
SOURCE: error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Posted on Feb 15, 2009
Tom@s21
  • 12 Answers
SOURCE: Di 183 J-- error
715ebf9.jpg7a749f4.jpg good luck!
Posted on Mar 02, 2009
Di 470 toner bottle error
follow this link it may help
printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=Di470..
Apr 06, 2017 | toner Office Equipment & Supplies
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
Displat code C10A5 in minolta di470
Press the Trouble reset switch on the tech.rep.setting switches board to reset a malfunctions,or open and close the front door and turn OFF the copier wait 1 minute and turn ON.2_5_2013_6_54_09_pm.jpg2_5_2013_6_54_24_pm.jpg2_5_2013_6_54_38_pm.jpg
Feb 05, 2013 | Konica Minolta Office Equipment & Supplies
Firmware on to minolta di470
Step 1:
C-10XX Memory board failure.Enter in the service mode and reset the trouble.2_6_2013_6_19_30_pm.jpg2_6_2013_6_19_42_pm.jpg
Step 2:
If you can t reset you have remove the right upper cover and the memory board metal cover to located a memory board reset microswitch.2_6_2013_6_27_55_pm.jpg2_6_2013_6_28_08_pm.jpg
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Pagepro 5650 "fuser error 0500"
You have to call a tech, to remove the fusing unit and try to fix it. In the worst case scenario, you have to replace the fusing unit, which is not very cheap.
May 14, 2009 | Konica Minolta PagePro 5650EN - Printer -...
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
408 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
