Question about Home Security
Bumil safe LOST COMBINATION; The Safe is open, latch-pins are out, and the key is in the center-lock. How can I reset the combination so I can use the safe.
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Posted on Jul 09, 2008
SOURCE: Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Posted on Sep 21, 2008
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: how to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Posted on Jan 06, 2010
SOURCE: have sentry so310 safe lost
Lost combination can I still open safe
Posted on May 29, 2011
I have bumil sd 103 safe and I have a key but I forgat combination codes...please if anyone know the solution.....
Unfortunately, according to this expert, you will need both the key and combination. You'll have to have proof of ownership and contact certain people to try to get the combination.
(It's a Bumil sd 102, but they should be the same)
http://en.allexperts.com/q/Locksmithing-3110/2015/2/t-bumil-sd-102.htm
Sep 08, 2016 | Home Security
I lost the combination of my sentry safe s0310
refer to owners manual for reset code or contact lock smith
Mar 16, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
Locked safe
I have a s0409 safe,I have the key but lost the combination to it,what do i do,it has numbers ah-447659* sticker on it.
Mar 18, 2010 | Schylling Combination Steel Safe
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
I have a sentry safe with a key and combination lock i have misplaced my combination now what
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jul 13, 2009 | Sentry Fireproof Safe
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Home Security Logo
41 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
