Question about Acer Computers & Internet
Acer Travelmate 5742 wont charge battery
Acer Travelmate 5742 will not charge the battery. I replaced the charger with an original Acer 19V 3.42 Amp unit from acer and the battery too with a brand new original one. Machine works fine, but will not charge the battery. The same charger and battery works fine in another notebook.
  • Riaan May 06, 2013
    It turns out that the main board was a bit damaged, and Acer wanted to replace it which cost more than a new laptop. So then I searched and found a service manual for the Acer travelmate 5742 series (covers some other models too) but this only told me how to disassemble the unit and not what to check exactly on the main board. So then I found out the motherboard is made by Compal model LA-5892P, and I searched for a schematic diagram for it and found it on some Russian site. On page 39 of the manual is the entire charging circuit. I found that a diode (PD13) has broken off the board, so I replaced it.
    The entire charging circuit is driven by PU17 which is a ISL6251 battery management chip, and all the components around it.
    If you can solder neatly and you can diagnose a little electronics then this link will be helpful:
    http://www.s-manuals.com/manuals/motherb...
Specs ms2132
I hope this is useful; it's rather scanty
From the 2300 TM series manual (available from the acer website): 65W AC adapter 19V 3.42A
Or have a look at this
http://www.ukbatteryfast.co.uk/acer-travelmate-230-power-adapter-charger-p-1130
webpage. I think it's for a compatible power adapter, rather than an original Acer one, but it gives pictures of the connector.
Try www.acer.com > support > chat and see if they can be more helpful and specific
17.April.2014
Dec 13, 2013 | Acer TravelMate 230 Series Laptop Charger...
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
AC adapter 4750z
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
I have an acer 8371 not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
If you can confirm your laptop charger is dead, just purchase a new one:
Replacement Acer TravelMate 8371 AC Adapter 65Watt 19V 3.42A
Oct 26, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Ive replaced my laptop battery.......it does not recognise...or c
since putting back the old ones charges the battery, then the charger unit is good. its best to replace the old battery pack with the same rating. the charger might be having some difficulty due to a higher rating of the new one.
Jun 08, 2009 | Acer Computers & Internet
Acer travelmate 8204WLMi charging problem
the only repair centres are in uk that give you the turn your laptop arround in the time you need if you type in laptop repair centres in search browser and you get all repair centres listed. I've hunted for 20-30 mins on repairs to laptops in USA but not much available on your laptop model. good luck on finding a service centre for your laptop
Aug 15, 2007 | Acer TravelMate 8204WLMi Notebook
Acer Travelmate 270 - battery problem?
IT sounds like your laptop or powersupply/charger is at fault. Try to use a different charger, and if possible use your battery in a different computer. That way you can narrow down where the problem is. It might ba a faulty connection where the charger is connected to your computer. To check this out, try running the computer on AC without the battery installed. If it suddenly shuts off it's a problem with your powersupply or possibly the connection plug in the cimputer.
Apr 24, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
