Question about Dell PowerConnect 2224 (0M4575)
Default ip What is the factory default IP
  • 22 Answers
The PowerConnect 2224 is an unmanaged switch. As such, it should not have an IP address at all.
Posted on May 08, 2013
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
How to reset to factory default, how to know the ip default.
Default ip: 192.168.1.1
user name: manager
password: friend
Jul 08, 2014 | Allied Telesyn AT Computers & Internet
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
How do I reset an Ip i2002 phone to factory default
Go into settings and it should be at the bottom "Restore to factory default"
Feb 23, 2010 | Nortel I2002 IP Phone w/Text Keycaps, No...
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
Reset a 1140E IP Phone
If you are running C6E or later firmware, then the following keypad sequence is used to reset all provisioning paramaters to a "factory default":
[*][*][7][3][6][3][9][MAC][#][#]
Where MAC corresponds to the MAC address of the IP Phone which can be found on a label on the back of the IP Phone.
Since a MAC address can contain the letters A-F, then letters A/B/C can be entered via the [2] key on the dialpad, and letters D/E/F can be entered via the [3] key.
For example, an IP Phone with MAC address 00:19:E1:E2:17:12 would be reset to "factory default" when the sequence **73639001931321712## is entered on the keypad.
Apr 08, 2009 | Nortel 1140E
Lost Default IP Settings screen after Mult. Interface Table
You have to do a factory reset to the device or it wont go away, make sure you dissconnect ethernet cable when doing the factory reset.
Jan 30, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
How do you do a factory reset on the Mitel 5220 IP Phone ?
To Restore Factory Default Settings:
1. Press both Up and Down Arrow keys simultaneously while powering up the
phone. NETWORK SETTINGS? appears
2. Press NO until TOOLS & FEATURES appears and then press YES.
3. Press NO until RESTORE DEFAULTS? appears and then press YES.
4. Press CONFIRM. The phone resets with default settings.
Nov 25, 2008 | Mitel 5220 IP Phone
How can I restore the default ip 192.168.1.1 to the port?
My name is Laxman,
you can restore the ip in two ways ;-
1) if you are familiar with the Router web interface configuration, just follow this instruction...
connect the computer to the Router's Ethernet port. Check the default gateway ip on the computer ( for exmple: 192.168.20.1 ). open internet browser, in the address bar type the default gateway ip as ( example: http://192.168.20.1 ) and it will prompt for username and password ( by default no username , its blank., Password is " admin " ). then you can login to the router page and see Setup page. you can find " Local IP address " ( for example it might be : 192.168.20.1 ). you can change it to "192.168.1.1" which is default one.
Let me tell you the another way which is very simple :
2) At the back of your router, you can see tiny button like a pin hole labled as RESET. you can press it with the help of pencil or paper clip for more than 45sec. your router ip would be set as default one ( 192.168.1.1 )
Warning: Pressing reset button will let you lose all settings on the router to factory defaults. user name and password , wireless settings, local ip address etc., would be set as factory defaults. you need to re-configure the router.
Nov 16, 2007 | Linksys Wireless-G WRT54GS Router...
Dell PowerConnect 2224 (0M4575) Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
