My emachine T6534 after being booted will shut itself down after 10 minutes. the power button blinks continuously. I have to remove power cord in order for it to cease. what could this be
    Sergeant:
  • 180 Answers
Temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
Posted on May 09, 2013
danasaur
  • 77 Answers
SOURCE: nx 6110 boot up issue
None of the above. Sorry. All those "solutions" are "shooting in the dark". There is a definitive method of determining the problem here, without guesswork.
The "HP screen" you speak of is an "advertising mask" governed by the "quiet boot" option in BIOS.
This HP screen is shown INSTEAD of showing you exactly what BIOS is "doing" at that moment: First, a ROM checksum to verify BIOS is OK, then a quick system check of the most basic components, and if that goes well, the next thing it does is count AND check the RAM. Finally, after all that is done, it will look for a hard drive and query that drive for cylinder or LBA size, then look at MBR for sector zero, to find an operating system.
So here is what you must do to SEE all that taking place:
1. Make sure the system is TOTALLY cold (off, not in any ACPI state). Do this by pressing and holding the power button for 10 seconds, then release.
2. Remove Battery and the PSU (AC power supply)
3. Insert the PSU connector (only) this will also eliminate any battery problems. Batteries with dead cells can pull out so much current that you get slow boot/running performance. More on this later.
4. Now, start the computer, and keep pressing ESC key, quickly. It may start beeping. Stop and wait then.
5. Next, you will see a BLACK screen instead of HP screen. There will be some white text that scrolls. First the BIOS type and version. Next, RAM will be counted, and last, a HD will be reported. Last (or if any of the above have a problem) any errors will be reported. Some BIOS will specify the error, others will report it as "code XXX". Send me (post) this info, and I will analyze the problem.
NOTE: you can hit the PAUSE key at any time, to read the info, if it runs too fast for you. Then press PAUSE key again, to resume the BIOS data post process. Once you have reported back with any errors (as in step 5 above), we can also do this same thing with Windows, to "see" the black screen/errors reported as the PC boots.
Posted on Jan 24, 2008
  • 81 Answers
SOURCE: blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Posted on Nov 30, 2008
  • 987 Answers
SOURCE: Toshiba laptop will not boot - black screen
The RAM might have problem...
Posted on Jun 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
  • 193 Answers
SOURCE: my laptop, emachine m5312 shuts down by itself
it may be set to hibernate in the bios. if it's randomly shutting down while you are working then you probably have an overheat issue.
Posted on Aug 14, 2009
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
It shut down automatily
Shuts down when? Immediately when you start trying to boot it? And if nothing ever posts on the lcd screen your problem is either the memory or the video card most likely.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 30, 2012 | Computers & Internet
Emachine e627 laptop powers up and shuts right down
This could be a memory problem or a Video Problem. It could be a sign of overheating but if you had it sitting for a while then tried it and it does the same thing then the laptop has not been on long enough to overheat.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 08, 2012 | Computers & Internet
Toshiba satellite will not turn on
LOL at your comment to take it to Best Buy to the Geeks.
May 01, 2012 | Computers & Internet
Cq60-615dx power problem
Mar 31, 2012 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Emachine 725 keyboard does not and machine hangs up
Re-boot and see if it happens again. To shut it down, press and hold the power button till it shuts off. Remove the battery and power adapter and then hold down the power button for about 10 seconds. Then re-install the battery and adapter. Push the power button to energize the laptop.
Nov 04, 2010 | Acer Computers & Internet
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
