Horizontal underscan on sony trinitron tv KV-32DS60U
Some programs being shown (ad hoc) as 25" picture (with 2.1/2" black border each side)-any channel any program anytime since joining TalkTalk YouView - but commercials will be in "Full" screen until program resumes - was with Sky & this has never happened before - but when a new program starts on same channel - picture may resume "Full" screen ?!
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
techman
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • 1694 Answers
SOURCE: sony trinitron wega KV-XR TV
Activate / de-activate by pushing display button on any Sony
remote control........................T.
Posted on Jan 08, 2008
SOURCE: Sony Trinitron 21 inch KV-G21M1
what is the securet code of this tv. No picutre, sound but video mode is good. how to solve this probles.
Posted on Feb 18, 2010
  • 17 Answers
SOURCE: Sony FD TRinitron WEGA,
Just went thru the same problem with my sony kv-34. There are two IC's on the D circut board located on the left side looking from the rear. If you can solder 18 pin IC's without making a mess it is possible.If you have a friend thats real good with a pencil tip solder device. I recomend putting sockets in where the IC's were as you won't have to worry about overheating stuff next to the IC's.Do a google search: Sony led flashes ad select the second hit in the list.
Good luck
Rich
Posted on Jun 06, 2010
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Sony WEGA 36" Trinitron HD
Check for unit posting any blink codes on the timer LED. Google "sony blinking codes" for the explanation. Try turning unit off for 4 hours to force a hard reset of your set, you need to unplug it. Sounds like a low voltage problem in the HV circuit.
Oct 29, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
