Question about Samsung HP-S5033 50 in. HD-Ready Plasma Television
Digital tuner My HP-5033 TV tuner uses a dash for digital channels and my cable system uses a dot. Is there any way to make the tuner recognize the dot?
    New Friend:
Fyi, i gave up trying to get digital on mine several years ago. nothing i tried could get the xx-x digital channels. nothing i have searched for online gave an answer (that worked). nothing in the manual except for entering station number followed by - followed by number(s).. as you stated.
my other sets i have work fine in auto programming and get digital '-' stations just fine. so i use them, but it would have been nice to have this model work too.
if either of us get the answer and get it to work, post please!
Posted on Jun 01, 2013
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Does a r57w46 zenith tv need a converter box
General rule of thumb: If your original remote does not have a dot ( .) or a dash ( - ) near the numeric buttons, the TV is does not have a digital tuner. These buttons are used to directly enter a digital channel number such as: 19.1 or 19-1. After looking at your TV specs, this TV needs a converter box if you plan on using a roof top antenna. I hope this was helpful, best wishes.
Jun 29, 2010 | Zenith R57W46 57" Rear Projection...
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
Conversion
does the remote have a dash or dot button on it? if so it has the digital tuner, you need the dash or dot button for the digital channels such as 2.1 2.2 7.1 7.3 etc...
Jun 11, 2009 | Apex Digital PF3230 32" TV
Play & Record VHS through TV Tuner Card
You need to connect the ariel to the vcr, then the vcr to the card, using a male/female fly lead. Then I suggest putting an origional film tape into the vcr, press play on the vcr and then scan in the channels on the card. It should pick up the vcr's output of the film that is playing.
Jun 05, 2009 | HP Expresscard TV Tuner For Windows Vista...
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Catching one Channel Only
A TV card probably wont be able to tune it in...or decode(decrypt) it for that matter. Is a CableTv set top box plugged in? (the box your cable company supplies you with) -damian
May 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
Dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Samsung HP-S5033 50 in. HD-Ready Plasma Television Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
