Question about Tascam DP-24
Tascam system error 50
Code 50 pops up, wont burn a cd, freezes , wont power off all the time
SOURCE: tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Posted on Dec 18, 2007
  • 189 Answers
SOURCE: Tascam 788
Sorry to hear about your problem. A number of things could cause this error to appear including bad sectors on the hard drive (which will require a reformat).
Two things you can check though before getting into replacing or reformatting the drive (which will erase all of your data) are 1) Make sure the power adapter hasn't failed. A bad or incompatible adapter won't provide enough power to the drive when it tries to spin up and could cause this error. You can try a replacement after-market adapter but you'll have to match the specs in the manual. 2) You can open up the 788 and inspect the two wires connecting the disk drive to the motherboard. One is power and the other will be an IDE ribbon cable. If either is loose that could be the cause of your problem.
If you do determine that the drive is bad you'll need to remove the drive, hook it up to a PC and reformat it there. Then reinstall it in the 788 which will upon bootup automatically reformat it again with Tascam's proprietary disk format. You can optionally replace the drive. I believe Tascam's site has a list of drives which are compatible with the 788. Reformatting (or replacing) the drive will obviously cause all of your data to be lost, but should get your 788 working again (if a bad format was the problem).
One thing of note if the drive format being bad turns out to be the problem is that Firmware versions 1.07 and below have a bug which can cause bad sectors to corrupt the drive after delete operations. If you have a firmware version which is 1.07 or below you should upgrade to a newer revision or you'll risk corrupting the drive again in the future. You can get the upgrade and instructions on how to apply it here: http://www.tascam.com/products/788;9,16,132,19.html
Best of luck and hopefully it's just a loose connection or a bad power adapter.
bd.
Posted on Nov 12, 2008
  • 189 Answers
SOURCE: tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: Problem with Tascam Cd-RW750. system error at
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
Posted on Sep 27, 2009
SOURCE: recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Posted on Jan 15, 2011
Tascam DA88 has error light and wont play tape or show time code
These are expensive to repair and not many people are repairing them. Probably a transport issue and that might be all there is.
If you look on E bay they are selling cheap.
Feb 16, 2015 | Tascam Audio Players & Recorders
Tascam cd -rw 900 sl wont play cd burnt from my laptop
Make sure you are burning the audio files in a format it can read. The standered is Mp3, but some times you need to burn them in other formats.
Apr 05, 2014 | Tascam CD-A500 CD Player
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
da_monk_bomberman@hotmail.com
if i can get some info on it ill contact yah ok
Dec 08, 2010 | Tascam DP01FX All-In-One Recording Package...
Will not play a Memorex cd-rw
try again! burn an audio cd, but burn it at max 12x speed!!
Oct 28, 2009 | Tascam CD-RW4U CD Recorder
How do i import the tracks from a cd to the track board?
i tried everything to import my rap beat into my tascam 2488 neo it wont let me says that i want a anotrher cd
how do i know which cd to put the wave file in cuz all i did were convert the beat into wave file in itunes and burn it as data on the cd and it wont do it i also burn it as music on the cd it wont do it what do i do?
Jul 25, 2009 | Tascam 2488 Portastudio Multitrack...
Recording stops and recorder freezes with tascam 2488mk2
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam dpo2 not burning a cd
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 788
bd.
Nov 12, 2008 | Tascam (cd-rw788) Burner
Tascam dp-01fx system 50 error
Nov 07, 2007 | Tascam DP01FX All-In-One Recording Package...
Tascam DP-24 Logo
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
