Question about HP PHOTOSMART 5510 E-AIO PRNTR B111A US
Porque se apaga mi impresora cuando la prendo
Enciende por unos segundos y lugo se apaga
puertobori
  • 7733 Answers
SOURCE: MI IMPRESORA HP LASERJET 3380 LA PRENDO Y APARECE
Go to HP Support & Drivers 1
Posted on Oct 13, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
puertobori
  • 7733 Answers
SOURCE: Buenas tardes soy de Peru tengo
Si tiene elCD de instalcion vuelva a instalarlo con el CD o baje (recomendable) el driver en Go to HP Support & Drivers.
Para poder ayudarlo mejor vuelva e informe que SO estaba usando y que SO esta usando ahora.No esta nada relacionado con su internet
Posted on Dec 15, 2010
seeker5211
  • 1089 Answers
SOURCE: mi problema es que cuando
You are going to have to get the Scanner Assembly replaced.
Posted on Jan 23, 2011
  • 628 Answers
SOURCE: Como puedo instalar la impresora
Obtain the software from www.hp.com/support.
Posted on Feb 26, 2011
El tablero de un 99 alero no enciende y el carro tampoco lo trato de encender el carro y se queda prendido por 1o2 segundos y se apaga todo tiene corriente menos el tablero
tengo un alero 99 y no funcionan la cuatro agujas del tablero y tampoco enciende el carro bueno si enciende pero por unos segundo y se apaga espero me puedan ayudar gracias
Sep 20, 2013 | 1999 Oldsmobile Alero
Video de como limpiar impresora hp psc 1410 con problema de que no imprime
Disculpen tengo una hp 1410 pero no enciende prende por unos segundos cuando la conecto a la corriente electrica y despues ya no enciende por su repuesta muy agradecido
Jan 27, 2012 | HP PSC 1410 All-In-One InkJet Printer
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mi tucson 2005 tiene problemas al arrancar. hay que intentar dos veces para que encienda
tengo problema con mi hyundai tucson 2005 de 4cilindros y 2.0cc
el encendido es lento como cuando rompe la correa del tiempo y al mucho rato de darle es que enciende con la marcha inferior a las 1000/RPM y a unos 5 segundos se apaga, le cambie la bomba de la gasolina, los inyectores, filtro del aire, estoy cansado de esto, que sera?
Mar 07, 2010 | 2005 Hyundai Tucson
HOLA NECESITO EL TIEMPO DE UNA ISUZU RODEO 1995 4 CILINDROS. CUANDO LA PRENDO TIENE UN FALLO QUE HACE COMO UNA EXPLOSIONES EN EL MOTOR, Y ASI CORRE. SI TIENEN LA SOLUCION SE LOS VOY A AGRADECER...
Tengo una isuzu rodeo 1995, empezo a encender la luz de check engine y se me apagaba y no queria encender...luego encendio, a veces hace como si no tuviera gasolina pero a veces enciende y se apaga, la utilizo asi pero cuando enciende el check engine se queda sin corriente y se apaga por completo, le lleve a hacerle un chequeo y ni el tecnico encontro nada, me pueden ayudar con ese problema?
Nov 29, 2009 | 1993 Isuzu Amigo
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
No enciende
Los "pi" que escuchas en tu computador son codigos que la tarjeta madre envia para comunicar que hay algo que anda mal.
Dependiendo de la cantidad de "pis" y el intervalo entre ellos se puede descubrir cual es la pieza dañada.
Mencionas 6 "pi", y deben tener un intervalo quizas de 1 o dos segundos entre ellos.
Eso es definitivamente daño de memoria.
Para asegurarte cual es el modulo dañado, solo remueve toda la memoria que tienes instalada, y enciende tu computadora sin ellas..
Veras que los mismos "pi" siguen apareciendo.
Aprovecha y limpia los conectores de polvo etc.
Si tienes solo un modulo, entonces reemplazalo para que se solucione tu problema.
Si tienes mas de uno, instala uno a la vez para detectar cual es el bueno.
Asi tu computadora trabajara otra vez.
Jun 14, 2009 | HP Compaq dc7600 Convertible Minitower PC...
Tengo telefono GE modelo 27831 x 2 y uno de ellos no funciona
La solucion es super sencilla, simplemente debe poner el auricular auxiliar en la base principal durante 10 segundos y luego ya va a funncionar, por que es la base la que que debe identificar el teléfono, ya que la base auxiliar solo es un cargador.
Saludos...
Apr 04, 2009 | Uniden Cordless Phone
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
HP PHOTOSMART 5510 E-AIO PRNTR B111A US Logo
82 people viewed this question
Seeker5211
Seeker5211
