Question about Protex Safe HD-34C Top Loading Small Electronic Burglary Safe w/ Drop Slot
Batteries died in safe! Cannot find the backup battery box! HELP
The batteries have died and I cannot find the back up battery box! I need it open ASAP! What do I do or where can i find another battery box?!!? Please help!
Need to open a Sentury safe key pad only the batteries died
without knowing the model the best i can doe is link you to you tube and some of the fixes there. i used this search term how to open a sentury safe key pad only batteries died. you may try other terms to get different videos on how to do it. good luck.
https://video.search.yahoo.com/search/video?fr=crmas&p=how+to+open+a+Sentury+safe+key+pad+only+the+batteries+died%3F#id=1&vid=1b6eaea93a88d9929e8b1ce283d04996&action=click
Oct 23, 2017 | The Home Security
Tip
How to open a 2087d Honeywell safe if you lost the battery backup
Honeywell no longer sells the battery back up! I made my own by putting 4 AA Batteries in a series, found a USB cable that matches the plug on the safe door and cut the USB end off the wire. Strip the two wires Red and Black and put the red on the positive side and black on negative side plug it into the safe and put the combo in then turn the handle and open the safe. You can make a battery by going to an electronic store and tell them what you are looking for or if you have a toy at home that has 4 AA batteries you can wire it into that Temporarily open your safe and give the toy back to your kids. LOL
on Jan 11, 2017 | Honeywell Safes 2087 Waterproof Fire Safe...
I got an offer to buy a safe called safewell No 13119956, her batteries are from inside, digital & key? let's say the batteries died how can i open it?? please any help?
is the safe closed? if not I would write the numbers with key code and put it in a safe place so will remember when its closed and then I can open it.
Jul 22, 2015 | Home Security
Safewell safe EX2007316659 batteries dying and can't open
I have had zero success in finding out any information about various models of electronic safes--no manufacturers' website, no online manuals, etc. Many of these safes are imported from overseas manufacturers.
Dead or dying batteries is a common problem, and I gather that many models of safes come with an override key.
It is incredible how many people have found the best place to keep their override keys and/or instruction manuals is INSIDE their safe!
I ask that anyone with owner's manuals or instruction sheets please publish them on this website for the benefit of others, but that is unlikely as they aren't the ones seeking information--they already have it!
Sorry I can't be of more help!
Nov 10, 2011 | Locks & Locksmithing
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
Batteries died. changed out batteries now shows remote is in "safe mode!" help please
If you remove the batteries for about 10-20 seconds and put them back in, it will take it out of safe mode.
If that does not fix it, press and hold the power button while you put the batteries back in and then remove the batteries again for 10-20 seconds.
This should fix the issue!!
Have a nice day!
Jan 11, 2010 | Logitech Harmony 550 Remote Control
How long do batteries last? How do you replace batteries?
Why don't you just replace the batteries yourself now and then you'll know when they were put in. The cost of 4 x AA batteries is pretty cheap for peace of mind.
Oct 07, 2009 | Safe International Digital Electronic Safe...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Batteries weak
Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Feb 08, 2009 | Safe International Digital Electronic Safe...
Protex Safe HD-34C Top Loading Small Electronic Burglary Safe w/ Drop Slot Logo
55 people viewed this question
Top Protex Safe Home Security Experts
Lawrence Oravetz
Are you a Protex Safe Home Security Expert? Answer questions, earn points and help others
