Question about Boating
55 hp Mariner 2stroke 3 cylinder. No botton end power.
I found this problem recently. When I punch the throttle the engine "stutters", almost like its getting to much fuel to quickly, for a few seconds before it starts going and when at speed it runs like hell. What could be the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Make sure all cyls working , running , and with airbox off while ticking over advance thottle slightly and make engine struggle place your fingers over each intake slightly to see which cylinder picks up , then thats the carb to clean the most ie , youve taken all carbs off so clean all ! P...
Posted on Dec 11, 2013
2 Suggested Answers
SOURCE: Yamaha outboard engine. Model f20leha manufactured
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
Posted on May 02, 2012
Is it 2 stroke or 4 stroke
look at the engine and if you have a cap to remove and put engine oil in then check with a dipstick then you have a 4stroke if you done then a 2stroke ! do you put 2stroke oil in the fuel , if yes then you got a 2stroke !!!!
Mar 23, 2015 | Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
WHAT IF I PUT GAS WHERE THE OIL GOES
if you mean where the chain oil lube goes then you could have a fire if any sparks occure ! If its where a seperate 2stroke oil feed should be then you will not lubricate the engine internals and sieze the engine ! Just drain out and fill with oil , 2stroke will need to be bled on the side of oil pump !
Jul 05, 2014 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Why does it idle fine and then when you give it gas it boggs down
A two-stroke engine idles because a very small hole behind the throttle plate lets a tiny amount of gas through to keep the engine running. At full throttle the air moving through the carburator pulls gas through the venturi vaporizing it. With the motor at idle, if you give the motor full throttle very fast the first charge or two that get into the cylinder are almost completely fresh air with vary little or no gas mixed in. It takes a revolution or two for the motor to pull air through the carburator fast enough to get a fully charged mixture of gas and air into the cylinder so you get full power. This effect is especially pronounced when the motor is cold, the gas doesn't vaporize as well when the motor parts are cold. If you give it throttle slowly or let it warm up the effect should go away.
Feb 22, 2012 | Poulan Pro PPBP300 30cc 2Stroke Gas...
No spark on yamaha dtr 125cc
Sounds like you are flooding the engine with gas. Put in a new spark plug then twist the throttle one time to prime the cylinder. Now get your hands off the throttle and give it a few kicks. Each time you twist the throttle the power valve gives a shot of gas. Too much can flood the engine quickly.
May 17, 2010 | 2000 Yamaha DT 125 R
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
When accelerating the engine seems to stutter.
Try unplugging your Mass Air Flow Sensor (MAFS) - you'll find it on top of the metal body immediately after the air filter. I went through an 18 month ordeal - replaced fuel filter, fuel pump, dropped fuel tank and cleaned it, ran 55 gallons of fuel injector cleaner through the system - nothing! After reading some blogs on this car/engine, gave the MAFS unplug trick a try. The car instantly corrected itself (when you unplug this sensor, the engine control module reverts to factory default, allows sufficient fuel into the engine for unitterupted performance.) However, if this corrects your problem, it's only a temporary fix. Run it about 3 days - it you notice soot in the tailpipe, the factory default is running too rich. Replace the MAFS.
May 19, 2009 | 1997 Mazda 626
No accelration on the highway
YOU MIGHT CHECK THE CAT CONVERTER.
Mar 06, 2009 | 2000 Volvo S40
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
