Question about Bosch SHU3306UC Built-in Dishwasher
Water wont stop , machine keeps filling
Machine will fill and start running, but it won't stop filling up and the water runs over and out at front of machine
  • 25 Answers
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
Posted on Jan 25, 2008
  • 1462 Answers
SOURCE: how to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Posted on Jun 25, 2008
SOURCE: Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Posted on Aug 09, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Posted on Aug 05, 2009
  • 574 Answers
SOURCE: My bosch dishwasher runs fine, cleans fine, drains
water inlet valve isn't closing all the way closed. Need a new one
Posted on Jan 06, 2010
Testimonial: "Thanks for your help. The inlet valve makes sense, I was just wondering if they are prone to getting jammed with gunk and can be repaired easily."
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
Water won't stop filling the washer
water fill valve is probably stuck open. see if you can find a blockage or just replace it
Feb 03, 2012 | Kenmore HE2 Washing Machines
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
My Maytag washer Model:LAT6800AA won't run after it fill cycle. I replace the fill level pressure switch because mit would not stop filling no matter what setting the fill switch was in, now it fills...
Is your model number correct? Or is this the LAT8600AA? (typo?)
This wiring diagram is typical of most every LAT model as far as the water fill & agitation circuits:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28437491&pkw_=basket&model_id=26594&NewWindow=1
Can you select spin and have the maching spin?
Here is how to test the motor:
You can sacrifice an extension cord to build this test harness.
The direct connections for a motor run test involves making a test cord. The test cord will have 4 connections (2Y connections) I.e. each of the power / cord wires is split off to 2 terminal on each wire. This will run the motor. Reversing the motor is done by switching wires B and C
If the motor runs during this test. it is sure looking like the timer is bad.
If you can not see the end of the D wire it Connects where the BLACK wire was.
All wiring harness wires from the machine have to be removed for the test. Draw your own diagram for the wires you removed!!!!!!
Kelly
Jul 29, 2011 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Whirlpool lte6234dq3 / ser# mrs110204 washer fill up and won't stop. it keep over filling and running to the floor.. ,vince
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 10, 2011 | Washing Machines
Open Questions:
See all Bosch SHU3306UC Built-in Dishwasher Questions
Bosch SHU3306UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
