Agitator Removal m/n PAVT920AWW
Elba agitator removal
easy as remove cap off the top of the agitator,inside at the bottom there is aa wing nut undo anticlosewise and remove agitator
Jul 06, 2012 | Fisher and Paykel Washing Machines
Removal of the agitator for cleaning
This video will show how to remove the agitator. You probably should replace the agitator dogs while you have it apart.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Feb 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator removal to remove clothes stuck beneath
for the basic top loader there should be a cap on the top of the agitator you can pop off with a flat screw driver and then use a ratchet with an extension to get to the nut holding the agitator on, 1\2 inch or 9\16 socket, i think.
Dec 12, 2009 | GE Washing Machines
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
How to remove agitator for cleaning purposes
Hold agitator at bottom, grab cap on top of agitator and snap off, look down in side of agit and you will see white plastic cover with two handle like clips, reach inside with fingers and pull cap out, you will then see a bolt, unscrew bold, **** agitator out. Install in reverse of removal.
Oct 01, 2009 | Whirlpool Washing Machines
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
PAVT920AWW Noise in wash cycle no agitation
Your Belt still needs replacing or to be scuffed up with sand paper. If thes fails you need either new tub bearings or a transmission. either a 250-300.00 repair so tr the belt and rotate drain pump rotation while the belt is off
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Mar 12, 2009 | GE Profile WPSR3100W
Agitator removal
Yes it does, I believe the dispenser will twist an 1/8 turn and pop off. There is a cap with a handle below it that pulls out. The last part is a bolt. Try a 7/16 deep well socket with a nine inch extension, grasp the agitator and loosen it. Leave bolt intact and lift agitator from the bottom. Looking from the date if you have solved the issue this will stand as a general post for ag removal.
Jul 31, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
