Question about Saws
Ridgid seesnake camera wiring diagram - Saws
Ridgid 700 trips gfci
you have a wire that touch to the housing of the tool
or
the windings of the motor, a brush holder have a default isolation
this type of circuit breaker is disconnected when it detects a curent flowing through the ground
Nov 17, 2012 | Ridgid 41935 700 Power Drive 115v Threader
The blade broke off in my ridgid r3001.
Release the clamp as much as you can, spray with wd40 and either use something like a small piece of wire to free it or try banging it gently down against a piece of soft wood.
May 15, 2012 | Ridgid R3001
I"m looking for a wirimg diagram for a custom aplication for a 1997 softail motor w/ electronic points placed into a ridgid frame useing a dyna coil.
The wiring for the ignition system is determined by the ignition unit that was used in the build of the bike. Remove the timer cover plate on the "nosecone" cover on the right side of the engine. The ignition unit is sometimes in that compartment. Let me know what is in there, i.e. Crane HI-4, and I'll either send you a wiring diagram or refer you to a website where you can get the wiring for it.
As for anything else to do with the wiring, all I have are a few "stock" wiring diagrams. If you bike is a custom build, the wiring is probably "custom" as well. I've seen custom build bikes with simple 8 wire wiring harnesses and then others have a full wiring harness for all sorts of gadgets on them. So, as far as a diagram is concerned, I'm pretty sure you're on you own on that. The builder should have made a diagram when he built the bike.
Find out what brand and model ignition unit your bike has and repost to me. We'll see if we can't get you going.
Good Luck
Steve
Oct 12, 2010 | Harley Davidson FLSTF - FLSTFI Fat Boy...
MY RIDGID ROOFING GUN will not feed the nails and then jams up because it trys to shoot two nails how can i fix it?
I would look at the deeder area which is close to the plunger. If not properly oiled, it will jam up like this. See the link below and enter the model number (R175RND) to get the complete parts breakdown diagram. That should help you to open up the unit and check it out. Also examine any O-rings for signs of wear.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJLzi4D70aMCFQo65QodJDG7wQ
Aug 23, 2010 | Ridgid ZRR175RND FactoryReconditioned 134"...
The gun will fire but the plunger will not retract back up into the chamber.
This unit likely needs oiling +/or O-rings. See the link below and enter your model number to get a complete parts breakdown diagram. Focus on the o-rings for the main plunger assembly.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJj0yNXm0qMCFZxo5Qod9QMmug
Aug 19, 2010 | Ridgid 2 12" Angled Finish Nailer R250AFA ...
My ridgid table saw keep blowing up the breaker and also smell funny.
My guess is that your breaker is too small. You need at least a 20amp breaker and the correct 12-2 wiring for the saw.
Aug 09, 2010 | Ridgid Saws
I need a manual for ridgid wet/dry vacs model #wd16500
I was unable to find the model WD16500 instruction manual anywhere online. In fact I did even find a link to that products owners manual, but when I clicked through the page no longer exists on Ridgid's site. I was able to find the parts diagram for the WD16500, and the instruction manual for the WD16600 which is also a 16 Gallon Detach Wet/Dry Vac, also with a detachable blower, and the model that even replaced the WD16500.
I also left you the number to Ridgid if you'd like to contact them, they may be able to mail you a paper copy of the instruction booklet.
I hope this helps you:
Instruction Manual:
http://www.ridgidparts.com/pdf/WD16600.pdf
Parts Diagram:
http://www.ridgidparts.com/cgi-bin/etcTable?showTable=1&table=WD16500-Figure1&image=Vac
Phone Number for the Ridgid Company:
1-800-4-RIDGID
If this was helpful, please be so kind to rate my answer as helpful, this is what keeps me coming back to Fixya to help people with their vacuum related questions. Thanks alot, I really do appreciate it.
Chris J.
GoVacuum
Apr 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Saws Logo
21 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
