Question about Measuring Tools & Sensors
3.5 hp briggs and stratton model 9j902 govenor springs
  • 6 Answers
SOURCE: BRIGGS MODEL 446777 GOVENOR HUNTS CONSTANTLY
carb needs cleaned or replaced
Posted on Apr 30, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 3 Answers
SOURCE: what kind of oil does the 22 hp briggs stratton
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Posted on Apr 16, 2010
  • 63 Answers
SOURCE: The govenor rod cannot be adjusted. The springs
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Posted on Sep 22, 2010
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
Briggs and stratton 190 cc toro lawnmower engine runs too slowly for mulching operation. How can I increase rpms?
Mulching loads the engine much greater than collecting or side ejecting as the grass cannot escape, maximum revs should not exceed 3600, there will be a stronger govenor spring available, or bending the arm that connects to the spring, but do not exceed 3600
Jun 01, 2012 | Briggs & Stratton Garden
I have a 18HP B&S Vangaurd Vertical shaft on a scag walkbehind motor runs good untill I engage the blades then it seems to draw down to about half throttle until I disengage the blades then the motor...
Check the govenor spring to see that it is not stretched out or popped off...there should be a colored spring on the throttle plate where the throttle lever connects to...also, there are several holes in the plate where the spring attaches...these hole will set the sensitivity of the govenor...you may need to make it more sensitive to hold the engine speed high when engaging the blades
May 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have bought a 5 hp.briggs &stratton and the
my advise is to leave it....most are pre set.Most are a screw....turn clockwise for higher revving....is the motor under stress?...if so a small adjustment maybe in order.
Jul 22, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
5.5 Briggs & Stratton push mower running too loud
It could be the govenor spring. Get the model number, type and code and take it to a small engine parts store and get a new one. A new spring will slow down the rpm's and it wont be that loud. Make sure you remember how the spring was hooked up.
Let me know if this helps.
Thanks \
roundo4
Aug 25, 2009 | Garden
Measuring Tools & Sensors Logo
146 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
