Haier Energy Star ESA3183 Air Conditioner
Problem for Haier Energy Star ESA3183 Air Conditioner
Air Conditioner Error code?
By davidjgartsi on Mar 16, 2009
Recently I pulled apart my 3 split system air conditioner units(3 seperate rooms) and cleaned filters as well as most of the interior of the plastic housing.
Re-instated all 3 units and now one unit will occasionally display a message on the display that looks like "E5".
If I turn off the unit for 3 or so minutes and then restart then all is fine for another day or so.
The units are Ager Air Conditioner model RCL-12H.
Can anybody offer a explaination?
Best Solution
posted on May 06, 2009
Very Helpful)
richard636
Rank: Apprentice
Rating: 100%, 1 votes
E5 is a coil sensor problem,this can be caused if you have had dirty filters, damaged the coil sensor while cleaning it or a common problem on any air conditioners, ring the boys at ager on 33412663 as they are very helpfull and will rectify the problem staright away for you
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 21, 2009
Not Rated)
dlmcmasters
Rank: Guru
Rating: 90%, 378 votes
I couldn't find any info on the error code your are getting but I found the user manual. RCL-12H.pdf">https://ager-air-conditioning.com.au/images/stories/file/air-RCL-12H.pdf
It could be you didn't get a piece of trim back on right and it's causing the problem. I would disassemble the unit again and then carefully put it back together.
If you can find anything in the manual I would recommend call them or emailing them at:
https://ager-air-conditioning.com.au/component/option,com_performs/formid,1/Itemid,36/
Was this helpful?
Yes
No
Popular Solutions for Haier Energy Star ESA3183 Air
Questions and Unsolved Problems for Haier Energy Star ESA3183 Air
Do you recommend Haier Energy Star ESA3183 Air Conditioner?
Answer
Answer
Have 5,200 BTUair conditioner window air conditioner and my dog got a hold the remote and chewed it... (More)
Answer
Haier Window A/C unit won't come on - just reads E1
Answer
I have the air on and all of a sudden the furnace is not working, called repair man he said it was... (More)
Answer
Error code on Enigma SLR-35 air conditioner. The error code is L1, air con will come on for a minute... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier Energy Star ESA3183 Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
