Question about Poulan Garden
Reattach pull cord for poulan pro 125e string trimmer
Is there a diagram to get to the pull cord to repalce it
#1 Taper
  • 1040 Answers
SOURCE: How do you wind replacement line to the Poulan Pro
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
  • 76 Answers
SOURCE: replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Posted on Jul 16, 2009
  • 120 Answers
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
Posted on Aug 24, 2009
  • 8 Answers
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Posted on Apr 27, 2010
rycgl
  • 1545 Answers
SOURCE: RE: PP 335 Poulan Pro
No easy fix here unless you are somewhat mechancally inclined and want to tackle it yourself. Ya could save a good chunk of money doing it yourself...learn about the machine first-hand and hey....there really is NOTHING that can prevent it from happpening again! You just fix it, run it until it happens again!
Posted on Aug 23, 2010
Poulan pro how do i put the carb back togeither
There's only one way it can go back together. Go to ereplacement parts.com and pull up a diagram. Just put in your Model number in the search bar.
Aug 16, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater wt3100 carb and fuel line diagram
motor will start after several pulls but will only run for about 10 seconds,
Nov 01, 2012 | Poulan Pro 952711635 String Trimmer Line...
The pull cord on my poulan pro weedeater will not
Apr 27, 2010 | Garden
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Apr 10, 2010 | Poulan Garden
String for a Poulan Pro PPB330
Pull your spool off, and look next to the notches on the bottom of the spool. The decimal number is the size of line that you can use. Some spools will have more than one size listed; they can use either size.
Best regards, --W/D--
Aug 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Garden Logo
56 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
