Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
I have it connected to the pool side suction inlet and have the valves to the booster pump open, do I also have the skimmer open?? It is not moving
I have the polaris 280. I have the polaris line connected to the side suction of the pool and the booster pump valves open, the skimmer and botton suctions closed. It is not working. What am I doing wrong?
    Top Expert:
  • Polaris Master
  • 4,292 Answers
Polaris works on water pressure outlet pressure and a booster pump
Posted on May 22, 2016
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: Once the booster pump (for polaris 280) is turned
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Posted on Oct 03, 2009
  • 10 Answers
SOURCE: polaris is not sucking up pool debris
If the back-up valve is not cyceling this could definitely be the problem. Replace your Back Up-Valve. Also, check the hoses and swivels for leaks. .
Posted on Nov 05, 2009
john224
  • 1378 Answers
SOURCE: why is my polaris 280 booster pump is revving much
Thank you for posting your question here on Fixya.com.
The booster pump can not turn any faster than its nameplate speed. If you think it is revving up, it is probably because it is running louder and/or rougher than normal. The pump seal and/or bearings are becoming worn and will need servicing. A local electric motor repair shop should have the parts for you to buy or they could repair it for you. Often times a gasket will need to be replaced as well but all told the repair should be ~$100 or so.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 09, 2010
jharwell668
  • 640 Answers
SOURCE: I hooked up a new Polaris 280 pool cleaner to
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Posted on Jul 21, 2011
How do I fix a suction problem on my pool pump?
If return inlet fittings are STRONG with plenty of water returning, then that means water is being sucked from somewhere else in addition to your weak skimmer, Right?
So that means you must have another point of suction somewhere that is also open, especially with knowing, that suction at skimmer is weak!
To increase suction at any one point, close down other suction ports. In your case probably a second skimmer that is "tee, d" together, then in which case you will need to physically plug that openings suction port, if there isnt a valve to do so. Or your bottom main drain is open ?
May 04, 2015 | Pool & Spa
Can the Navigator be adjusted for the speed?
The Speed of a Navigator is adjusted by water flow. There is no adjustment on the unit itself. The more flow through the unit the faster it will go. If the unit moves too fast or too slow proper cleaning may be sacrificed. The proper flow can be achieved using the flow meter that comes with the unit.
Many pools are set up with multiple shut-off valves in front of the pump. These regulate flow from bottom suction lines, skimmer suction lines, and vacuum suction lines. If you have these valves, make sure the valve on the line the vacuum is attached to is fully open and then adjust the flow by closing off the other valves slowly until proper flow is reached. This is where the flow meter is used.
If there are no valves and the Navigator is moving too fast, an in-line valve is also supplied with the unit and can be used to regulate the flow. This valve is installed between the vac hose and the port where the vacuum is connected to the pool (side port or skimmer).
https://www.hayward-pool.com/pdf/manuals/PoolVac-Classic-XL-NavigatorPro.pdf
Sep 11, 2014 | Hayward Navigator Pool Cleaner
Hose connections from pump to filter etc
what are you asking?
do you want to know how to plumb the individual pieces of equipment?
If so, skimmer port at the pool will go into the suction port of the pump, the port directly into the hair & lint pot.
discharge off the top of the pump will go into the Inlet of the filter valve, then the outlet of the filter will go to either a heater inlet port then outlet of the heater to the pool return inlet ports. If no heater, then from filter outlet directly to the pool return inlet fitting.
Good luck
Jul 10, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
There is a 3 way valve that regulates water to the pump from my in ground pool. Is there a way to attach hose and vacuum without repeatedly unplugging and replugging the electrical supply? The suction...
1. My pump has a switch on the bottom of the back of the pump opposite the impellar, check yours.
2. Does the 3 way valve change where the suction is coming from? If so, when done vacuuming through the skimmer, switch the valve to the bottom inlet and skimmer suction should stop if the valve is working properly.
Gary
Jul 12, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
My creepy crawley has to much suction and gets stuck in one spot is there a way of turning the suction down
Attenuate your skimmer valve slowly to reduce the suction until the cleaner runs smoothly across the bottom of the pool. If you do not have a skimmer valve I would recommend installing an inline PVC valve in the suction hose close to the skimmer so that it is accessible. Close the valve slowly until proper suction is achieved.
Nov 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
How do i drain pool with hayward valve? setting is on waste but only drains hottub then looses prime.
you do need to set the filter valve to waste but you need to make sure the valve on the suction side of the pump is pulling water from the pool instead of the spa. Also, if you have a separate skimmer and main drain valve on the pool suction, make sure the skimmer valve is turned off. Otherwise, you will keep losing suction. If you don't have a separate skimmer and main drain valve, you may not be able to drain the pool with your equipment.
Nov 08, 2009 | Hayward SAND FILTER, PRO SERIES
How do I turn down the suction to the kreepy?
Partly open the valve to the bottom drain. If you have a jandy valve you can balance the skimmer and bottom drain. the more you open the bottom drain the less suction you have to the skimmer.
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
