Question about Dell Computers & Internet
Photojoy 64 bit - Dell Computers & Internet
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on May 06, 2013
Why photojoy is not working properly on windows8
Try right clicking on the Photojoy Icon , go to the Compatilibity tab and select "Windows XP Service Pack 3" from the dropdown menu , also tick the box that says "Run This Program As An Administrator" and then see if all features of the program work.
May 06, 2013 | Dell Computers & Internet
I have windows7 64bit every time i turn on photojoy a sign says NOT RESPONDING
Sometimes a software package is just simply corrupted. Since the photojoy software is a free software package I would simply remove it from my computer and re-install it.
If you want to try this go to Start button, control panel, then under "programs" click on "uninstall a program", then find the photojoy program from the list provided and uninstall it. Don't worry, you are going to re-install the same program.
Now go to http://photojoy.en.softonic.com/ (or your choice of online program suppliers) and click on the "Download" button for photojoy.
Follow the on-screen instructions and this will re-install photojoy.
Here's the deal... these programs are billions of bits in length, one bit out of place makes the system inoperative. It is much easier to just toss the bad one and replace it than to try to find which bit has gone awrey. This is not advisable on a $15,000.00 software package for a corporation, but OK for a free consumer package like yours. I'm a network administrator for several large corporations and we don't diagnos these types of problems, we replace them. It is much easier and much more effective.
This is how I would address this type of problem, if you feel comfortable doing this then go for it. If you don't then you need to find someone in your area to help you solve this situation.
Good luck, and if you have any further questions don'e hesitate to ask, that is what I love to do....solve problems!
May 17, 2011 | Computers & Internet
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Can i installed 32 bit applications on 64 bit processor?
The answer to your question above is Yes, you can install 32-bit applications on a 64-bit desktop/laptop. Please note 3 things:
1. The 64-bit environment will be determined by both the CPU and OS being 64-bit capable. If one of the them is not, then the system will not perform at the 64-bit level.
2. 32-bit applications can be installed on a 64-bit OS and they will function properly - but only at a 32-bit level. They will not take advantage of the 64-bit environment until the application is certified for 64-bit.
3. 64-bit applications cannot be installed on a 32-bit environment - they won't run at all.
Aug 25, 2010 | Microsoft Visual Studio 2005 Standard...
Computers & Internet Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
