Question about Saws
Jet jts10 Can not elevate saw blade
    Sergeant:
  • 468 Answers
What do you exactly mean? I don't have bench top saw but try to see this manual, you might need this .
Posted on May 06, 2013
Problems with 10in table saw, raising blade height. Very hard turning. Already clean unit and white grease
Need to know the brand and model in order to help you.
Many have elevating rods that the saw carriage moves up and down on - they get bent and the carriage won't move up and down.
Please post the brand and model and I will do my best to help
Feb 28, 2017 | Blade Saws
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
Jul 19, 2014 | Jet Saws
I can lower theblade but it is very difficult to raise and now its not raising at all just gets tighter until you hear a snaping sound
Try spraying the pivot points with soy based lubricant. It is very slick and should help ease the friction of raising the blade.
Apr 29, 2014 | Rockwell Tble Saw Series 34-335 Elevation...
Bevel gears are worn
Most common repair for this saw
1) remove blade & blade housing guard plate
2) You will find 2 allen head screws holding the elevating screw bracket
This will allow you to move the gears apart to replace
Remove the small retaining ring and slide the gear off (be careful not to lose the woodruff key when you slide the gear off)
Typically we find that the 2 rods (elevating shafts) are bent and this causes the resistance that strips the gears out - I always replace the 2 rods and the elevating screw when replacing the gears - you already have it apart and the parts are inexpensive.
Aug 31, 2013 | Dewalt Saws
Looking for a part for a jts10 serial # 003288
Please look for Jet parts at this link. You can search for your model at this page, and from there choose "find out more" to navigate to the parts list to obtain the part number you need. If yours is a JTAS-10 see this link, page 14-10.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 27, 2011 | Jet Saws
What is the band saw blade length for a JWBS-20-1 Jet Band saw.
The 20 inch band saw uses a 150 inch blade and I'm envious. The 20 inches refers to the wheel diameter
For more information:
http://www.redmond-machinery.com/Jet%20JWBS-20.htm
I'd gladly trade.
Feb 20, 2011 | Garden
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of...
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
May 11, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Saws Logo
20 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
